Results 1 to 7 of 7
Thread: VT Starting issues need help ASAP
    VT Acclaim S2
    Nov 2010
    Barossa, South Australia
    Exclamation VT Starting issues need help ASAP
    hi,
    i have a very annoying problem with my vt when cold it will crank fine but wont fire. when the problem first started i noticed the battery terminals where loose if i wriggled them the car would fire so i have replaced them as they did not clamp on tight enough the problem is still there iam now wriggling the wireing loom between the injectors and oil pressure switch this works most of the time. problem only seems to occur when the car is cold. any susgestions or help would be greatly appreciated.
    thanks,
    Justin
    VT Acclaim S2
    Nov 2010
    forgot to add car is a v6 series 2 acclaim, never stalls once running, going to replace the cas tommorow
    thanks again,
    Justin
    VT Acclaim S2
    Nov 2010
    i have now replaced the cas , the knock sensors and the starter motor. the starter motor issue is now fixed but i have now found using a noid light that my injectors arent getting a pulse when it wont fire so there is something stopping my injecters from working. any ideas what this could be
    thanks,
    Justin
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    Jarrad is offline Sherminator
    Silver Ex Cop VX Wagon
    Oct 2006
    Wollongong
    Hey Mate, I had a similar problem last week. I thought my fuel pump had died cos the car would crank fine, but not kick over. It gradually got worse over 2 days till it finally died.
    I had it towed to a mechanic thinking it will need a new pump. They tested the pump for power and it wasnt getting any.
    So they swapped out the fuel pump relay with another one and she started straight away.
    Might be worth swapping out your relay with another to check???
    Jarrad.
    Quote Originally Posted by monkeys437 View Post
    Its faster to drive very slowly than walk very quickly so hang onto your license and drive like a grandma for a year.
    Now you see me... Now you don't
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    VT Acclaim S2
    Nov 2010
    thanks guys fuel pump is fine can hear it pumping and dfi module has been changed several times
  1. VR starting issues
    By wylde_VR5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2011, 03:00 AM
  2. Starting Issues
    By I P Freely in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2009, 04:26 PM
  3. vp v6 starting issues.
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-11-2008, 04:35 PM
  4. Starting Issues
    By fennski1_au in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-12-2005, 07:36 AM
  5. VP Starting Issues!!
    By DUMPD_VP_CALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2005, 12:08 PM
