Results 1 to 9 of 9
Thread: VT Not starting
    VT II Berlina
    Aug 2009
    Hampton Park, VIC
    Default VT Not starting
    Hi,
    I'm having an intermittent issue with a year 2000 Series II VT Berlina (V6) on dual fuel (APA system, 3-4years old).
    It usually happens when cold, I'll turn the key and the car doesn't crank. I can hear some kind of ticking sound coming from the engine bay, but the car doesn't crank or fire. Following a few flicks of the key it eventually starts. I've noticed that the light on the lpg switch doesn't come on until the car cranks.
    I've tried it with two different keys, one old and one fairly new. I've replaced the factory immobiliser contacts, tried starting in both neutral and park, the battery is just over a year old and tested okay. The fuel pump in the car is two weeks old, problem was happening before this was replaced. Spark plugs and tune done at last service (~5000kms ago).
    Could it be the ignition barrel or starter motor?
    Cheers,
    Tim
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    The clicking your hearing is usually linked to a dud battery, make sure the terminals are connected properly. Battery's are susceptible to death in the colder months of the year... So head out and borrow a mates battery first and try that.
    VT II Berlina
    Aug 2009
    Hampton Park, VIC
    Would it be the battery even though the car eventually starts and runs no worries
    VQ S2 304
    May 2009
    Quote Originally Posted by TiMMy2410 View Post
    Hi,
    Cheers,
    Tim
    Had the same problem on a vt I had a couple of years ago. It was the battery in mine, but check your starter motor to see how old it is. Also, even if the battery is reading a "reasonable" voltage, it can still be on the way out
    VT II Berlina
    Aug 2009
    Hampton Park, VIC
    Quote Originally Posted by alpha_au View Post
    The battery is an AC Delco that was put in in August last year, reckon it could be on the way out already?
    How would I check the starter? Take it to the mechanic/auto elec?
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Yeah this even happened to me this afternoon, key in then click click click, vroooom... And I know it was the battery in my case because I was running the stereo for too long when I was cleaning it...
    VQ S2 304
    May 2009
    If it is the battery, like 304runner has said, it could have easily be flattened by a boot not being shut and a light kept on, or a stereo on for a couple of hours...
    Although, by the sound of it, it could be a sluggish starter motor, they're extremely easy to replace and only about $100 new
    VT II Berlina
    Aug 2009
    Hampton Park, VIC
    I think the problem is happening too regularly for it to be the battery, i'll get it tested tomorrow, if not look at getting a new starter motor.
    Thanks for all your help,
    Tim
    VX 'S' S1
    Apr 2005
    South East,Victoria
    My sons used to crank over very slow for the last 4 months with the symptoms of a battery with a low charge . I put it up on stands and found the fault to be that the nut that holds the battery cable to the starter motor was lose by about 1 and a half turns .I pulled it off and sprayed it with contact cleaner and now alls good
  1. EFI VK not starting.
    By '88 VN Custom in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-09-2009, 10:20 PM
  2. starting
    By ianf in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2009, 03:26 PM
  3. VL not starting, need help!!!!
    By treezey in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-02-2009, 08:01 AM
  4. Help Please Starting VS
    By obsessed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2007, 07:06 PM
  5. self starting car
    By SLugg in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-06-2006, 10:42 PM
