Results 1 to 11 of 11
Thread: VU suspension question
    Vu S II
    Sep 2010
    N/A
    Default VU suspension question
    i recently brought 18s for my ute. at the moment i have 15s with supers all round and stock struts/shocks. is i put the 18s on is it possible to go FE2 or ultra in the rear and keep the stock shocks or will they just shit themself? any advice welcome
    VU S2
    Jan 2011
    Quote Originally Posted by dutchysute View Post
    Sorry to go off subject, but would you have a pic of your VU on 15's mate?
    Considering if I should go sl on my interceptors and keen to see if your ute sits even with only a small gap between rims!
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    straight up, FE2 is an inch higher then what you have, ultra lows are an inch lower.
    stock shocks and FE2 springs will be fine.
    stock shocks and ultralows is a shit ride, but its still fine. will flog the shocks after a while though so look at upgrading!
    If it isnt tuckin, it must be suckin
    Vu S II
    Sep 2010
    N/A
    skotlar go to this link: Leons VU series 2 ute
    thats my car with the 15s on it
    DM 55 WA thanks for the advice. i might look at upgrading the shocks. cheers
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    yeah have a look mate, you will be fine without new shocks but its worth it for a better ride
    VU S2
    Jan 2011
    Nice looking ute mate!
    Is there much of a gap between the guard and tyre (couldn't quite tell from the angle shot)
    I'm wanting to lower onto my 15" interceptors and don't mind having a gap if it's minimal.
    Also, my ute sits a fair bit higher in the rear (possibly from the shocks the previous owner has put in?)
    Does yours sit pretty even on superlows all round or do you notice this angle with your ute aswell?
    Vu S II
    Sep 2010
    N/A
    theres hardly any gap between the tyre and guard. its a good height for the 15s. and mine sat high too with the origonal springs. all fixed now though
    VU S2
    Jan 2011
    sounds like the kind of look i want with my ute mate!
    so with your sl's all round does your ute sit even on stock shocks or still higher in the rear?
    i'm just worried i'm gonna have to go ssl in the rear for the even look but concerned when i load stuff in the back!
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    Quote Originally Posted by skotlar View Post
    If you go SSL's in the rear the rear will sit lower then the front. considerably, and you might have a hard time towing/loading stuff in the back.
    If you go SL's, the rear will sit slightly higher then the front (will sit pretty well flush with a full tank of fuel).
    VU S2
    Jan 2011
    Quote Originally Posted by DM 55 WA View Post
    cheers man, i know i've been asking a bit around this, just don't want to do the 'try and if i don't like, change' suggestion that mates had given me!
    if i lower with sl's all round, i guess i might get away with having my stock shocks without camber kit am i correct? (from what i can tell my shocks seem decent monroes already)
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    yeah fair enough lol, nothing worse then having to redo stuff!
    you will get away with stock shocks, eventually they will chew themselves out though (although ive had SSL's on stock shocks for 6 months and it runs fine). As you have a series II you already have the extra link in the rear end, so a camber kit isnt necessary (unless you can already notice mad camber) but with one you will have almost no camber.
    try and ask around locally, and see if any of the suspension shops near you stock lovells springs. i know with some of the places here that stock them you can just point to where you want it on the car and they can set the springs for you.
  1. suspension question
    By Vstemd in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-11-2009, 11:51 AM
  2. suspension question
    Last Post: 09-10-2009, 06:53 PM
  3. Does Vl Suspension Fit Vn ?, Just one question, Thanks
    By coops_23 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-03-2007, 08:14 PM
  4. Another suspension Question
    By evil_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2006, 05:46 PM
  5. Question on suspension
    By Rinn_P in forum General
    Last Post: 10-02-2006, 07:02 PM
