Results 1 to 6 of 6
Thread: Vu 3.8l not starting
    Vu ute
    Jun 2011
    Default Vu 3.8l not starting
    I have vu ute I installed a growler ss cold air induction
    And now vehicle starts but won't idle it just cuts out straight away any ideas someone ??
    vr commodore bt1
    Jun 2011
    As long as your mass air flow sensor is plugged in and your air temp sensor that's located in your air box, that should be it. There is nothing much else that can get mucked up
    Vu ute
    Jun 2011
    vr commodore bt1
    Jun 2011
    The air temp sender should just pull out it, damaging it would be hard. Check fault codes that will soon tell you
    REDHOT VX SS
    Jun 2010
    Quakers Hill, NSW
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Even if the MAF is ####ed the car should still idle an drive maybe a bit erratic, it should go into limp home mode, they did this so if the MAF failed you could still get your car to a safe place. May have nothing to do with adding the growler??? Just my 2cents.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
  1. RE; starting up....
    By VNpete in forum General
    Last Post: 04-06-2010, 12:21 AM
  2. vr not starting
    By jt_vrcalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2010, 05:04 PM
  3. VS Not starting
    By shadowmaster in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2010, 08:54 PM
  4. VN not starting
    By caekmaster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-07-2008, 02:33 AM
  5. Car not starting
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2006, 03:30 AM
