Results 1 to 18 of 18
Thread: VT brakes not very sensative.
    asdf
    Aug 2010
    asdf
    Default VT brakes not very sensative.
    I was driving a mates VX the other day and noticed his brakes are heaps more sensative and responsive than my VT's, I noticed that it was easier to put your foot down and there was a lot more braking force, did they change anything in the VX regarding brakes like master cylinder etc.
    His has ABS whereas mine does not, but this is just low speed braking where it wouldn't skid anyway. I do have good tyres and new heavy duty bendex pads.
    TI3VOM's Avatar
    TI3VOM is online now VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Are you sure your car does not have ABS?
    He probably has better brake pads than you!
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    VE S2 SV6/A6
    Apr 2011
    Do you know what pads your friends car has? Maybe something performance rather than heavy duty
    Current Ride: 2011 VE Sedan - In Voodoo of course.
    Last Ride: 2004 Subaru Liberty GT, Twin scroll turbo, tuned, Bilsteins, sway bars, no rice, 420Nm
    Also Own: 1964 EH Wagon, modified interior, minor modifications outside
    asdf
    Aug 2010
    asdf
    May 2004
    You probably have air in the brake lines. Try replacing the brake fluid with some super dot4 and bleeding the brakes.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    All comes down to the pad, the discs (to a lesser degree), and very importantly for pedal feel, the brake fluid and lines.
    Ronald Reagan (1986)
    asdf
    Aug 2010
    asdf
    vr commodore bt1
    Jun 2011
    It's the new heavy duty pads your running, high performance / heavy duty brake pads there a high heat brake pad, there less responsive when there cold but they hot they will out brake the STD pads. That's the difference. Not a lot of people realize this.
    asdf
    Aug 2010
    asdf
    vt s2 sedan
    Apr 2011
    brisbane
    asdf
    Aug 2010
    asdf
    Darcon666's Avatar
    Darcon666 is offline Evil is always around you
    The Wife
    Jun 2010
    At home
    RE: VT & ABS see here... Holden VT Commodore / Calais. So unless yours is an "Executive" and was never optioned up... ALL VX's had ABS as standard accross ALL models.
    Barring any issue with the master cylinder/slave... If it's not the air in the lines then the pads are too hard(Require more heat to operate correctly) with the new rotors.
    Did you bed the new pads to the new rotors?
    asdf
    Aug 2010
    asdf
    Yeah they are. From what I've read it sounds like there could be air in the lines. The ill bleed them and see how they go.
    asdf
    Aug 2010
    asdf
    Ok so I replaced the brake fluid and bled them and whilst it did help it still is nothing compared to my mates vx. Could it be a vacume problem or something like that?
  15. #15
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Quote Originally Posted by Darcon666 View Post
    From what I understand you don't need to bed in new style brake pads?
  16. #16
    VX S
    May 2010
    Melbourne, Victoria
    asdf
    Aug 2010
    asdf
    I have found that on the vx it feels easier to push your foot down on the brake pedal but on my vt theres a bit of resistance. Any ideas?
  18. #18
    VY SS
    May 2011
    Auckland
    Probably easiest to check the part numbers on the two boosters to see if they're different.
    Does his have bigger brakes? (rotor diameter)
    Could be any number of things, perhaps your calipers are getting a bit worn and sticking a little etc
  1. [VIC] vt sloted brakes-vy calipers, vr frnt/back stock brakes & calipers, vy braker booster
    By YILDI2 in forum Parts And Other Items For Sale
    Last Post: 23-03-2011, 02:12 PM
  2. Touch sensative kill switch
    By nfsuaddict in forum General Discussion
    Last Post: 24-11-2009, 03:16 AM
  3. [WA] Wtb hsv brakes
    By younglion in forum Swap / Wanted to Buy / Trade
    Last Post: 11-05-2009, 12:58 PM
  4. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
