Results 1 to 4 of 4
Thread: vacuum leak in heater??
    vn executive s2 v6
    Jun 2008
    Default vacuum leak in heater??
    hi
    the controls for the heater on my vt dont seem to be working properly.
    when i rotate the dial to set it to windscreen or feet/windscreen it seem to loose vacuum???
    were could it be loosing vaccum from? its like theres not enuff air or something and the more i rotate the dial i loose it on the other settings to??
    i have pulled damnd near the whole dash out so any imput is good
    Claudy's Avatar
    Claudy is offline French Com
    Manual Gen3 VT SS + V6 VT manual turbo
    May 2006
    Perth, Two Rocks
    Think there's a vacuum canister somewhere so one of those vacuum lines could be broken
    Gen3 6spd Manual VT SS
    VT V6 Manual turbo
    vn executive s2 v6
    Jun 2008
    hi
    i took the cover of the motor (v8) and theres a hose coming of the throttle body and goes to the drivers side valve cover, it has come out? it appears to have just been siliconed there? what is the correct way to reinstal?
    also there is a water hose above the thermostat that has a gismo with black vacuum line coming out the botom of it. it has a solinoid thing with a cable that can open and close it. its quite rusty and water is dripping out of it.
    would either of these things be my vacuum leak?
    vn executive s2 v6
    Jun 2008
    by vacuum canister do you mean like what vn-vs hade under the passendgers front guard? kind of a ball looking thing?
  1. No Vacuum at the heater tap...!!!!!!!
    By frontier in forum VY Holden Commodore (2002 - 2004)
    Last Post: 25-07-2009, 03:29 AM
  2. Vacuum Leak???
    By mazza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-09-2005, 02:53 AM
  3. VP Heater Vacuum
    By syncope in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2005, 07:43 PM
  4. No Vacuum at the heater tap
    By electradaz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-09-2004, 02:27 AM
