Results 1 to 25 of 25
Like Tree7Likes
  • 2 Post By itsagixa
  • 5 Post By TI3VOM
Thread: SICK VT CLUBSPORT help pleeeeese
    vn-1990 v6,5spd,vt v6 98,vs,ve ssv 09 ute
    Jun 2011
    outback, South Australia
    Unhappy SICK VT CLUBSPORT help pleeeeese
    We have a Vt clubsport and when its idailing it backfires/crackels but onlyever few seconds, its not blowing smoke etc, have changed the coilpacks,leads & plugs,air filter,done injecter cleaner ( it has sat in the shed for a few months).when its getting reved hard it runs sweet......... Got us buggered holdennikki
    vt ss v6 supercharged
    Dec 2010
    new zealand
    GSXR1000
    Apr 2010
    WA
    stop driving it like a nanna ? :P
    jkz... sorry can't help provide helpful feedback
    MikeCuzzy's Avatar
    MikeCuzzy is offline How hard can it be?
    2007 VE Omega 3.6L & 1998 VT Executive 3.8L
    Jan 2010
    Wollondilly, NSW
    Quote Originally Posted by vt super6 View Post
    could be bad fuel water in tank
    Plus one to that, fuel might have gone bad after all these months. That or older cars used to get a lot of condensation build up in the tank itself, though plastic is an insulator, so it's less of a problem these days- but still possible. Best bet would be the fuel has gone bad.
    The New Ride - The Class 2 Shuttle Craft (VE)
    I'll be he comes to get you, some shopping trolley kind of thing, that gets you where your going nice and slow... Well off you go that's fine, the pleasure's all mine.
    When I light the nitro on my HQ 454 Monroe!
    Jun 2011
    nah done the fuel!!!!!!!!, where are the oxygen sensers in these and is there two or four???????
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by DM 55 WA View Post
    on the manifolds arent they?
    Just after the manifold and there are two, one each side.
    MY RIDE
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    i knew it was something to do with the manifold lol
    If it isnt tuckin, it must be suckin
    MikeCuzzy's Avatar
    Jan 2010
    Wollondilly, NSW
    + 1 accentstencil
    So far as I know there are 2, and they are located on the exhaust manifold. Can't miss them, they're the only wires to the exhaust system.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Do you have a VT1 (Holden Engine) or VT2 (Gen III/LS1 Engine) ??? If you have a VT1 you can check to see if you have any error codes logged (check FAQs) which may give you a clue what's going wrong.
    When you say "nah done the fuel!!!!!!!!", what do you mean? Did you drain the old stuff and fill up with fresh fuel or what? Pour some methylated spirits into the tank, it will absorb any water that's in the fuel.
    Jun 2011
    vs commodore
    Oct 2009
    Tamworth NSW
    About 250mls or a cup full of metho to quarter a tank of fuel.That will allow any moisture in the tank to mix with the fuel,which then allows the water to go through to the engine with the fuel where it then gets burned off in the combustion process.I put a cup of metho in my tank once a month to disperse any moisture,Ive done this for years now..
    Jun 2011
    Cool
    o.k i will give that ago thanx ay i have heard of using metho but hav never used it myself, ay what type of gasket do you use when im replacing a intke manifold (whole unit)on a 2000 vx on fuel only meaning silcone,cork, etc
    1997 Vt GTS Build 78
    Aug 2009
    East Gippsland
    Few differant sortss of inlet manifold gasket are available. Usually you can only get the gasket you are after in a Valve Regrind Kit or engine rebuilt kit, If you look in the yellow pages and source a Local Engine Reconditioner they shouls be able to provide various options for your gasket requirements.
    For the record OEM standard inlet gaskets on 3.8ltr and 5.7ltr are a plastic/alloy/rubber composite.......Performance application usually find an alloy gasket assembly being used.......However OEM l67 3.8ltr supercharged engines still use the same inlet manifold gasket as a standard 3.8ltr ecotec engine.
  15. #15
    Jun 2011
    ]we have changed our leads and plug on the vt v6 automatic think it a ecotec lol, but it still is back firing its got a poping kinda sound while its ideling, but when i give it to it in park runs fine, when im driving it pops on deaceleration but splatters on aceleration, we also cleaned the airflow meters, can anyone give me some more pleeeeeese
  16. #16
    TI3VOM's Avatar
    TI3VOM is online now VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Hold on is the car a VT clubsport or a VT V6?
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
  17. #17
    VX SS
    Jul 2011
    if ya dont know the difference between the two maybe you should get a mechanic involved...
  18. #18
    Jun 2011
    Cool
    ummm no its a vt v6!.......... some ideas would be handy as i live 240kms from town and dont want to have to trailer it in, cos thats the only town car with dam tow bar!!!!!! aaaarrrrgh, and we dont like to drive the ssv in to town as the dirt roads arent the smoothest atm lol.....
  19. #19
    Jun 2011
    oh yeah sorry didnt mention we have a clubby too,but its not the same car im talking about m8
  20. #20
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    try doing a self diagnosis on it see if any fault codes come up.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  21. #21
    VT SS Series 1
    May 2011
    Wollongong
    after reading your posts in this thread, id say DONT TOUCH the car at all and get it to a mechanic...
  22. #22
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Quote Originally Posted by holdennikki View Post
    You thread is titled SICK VT CLUBSPORT help pleeeeese if your not talking about your clubsport then why title the thread about it?
  23. #23
    Jun 2011
    cos im still learning this site and i have been going through the same thing al time and we 8 cars which seven of them are holden commodores, which i have four that not running right, is that o.k................i only com on this site to get car info help, can anyone answear my questions so i can help these poor commodores lol, oh yeah the vs just got a new ignition barrel went fine then went to use it again and nothing but dash lights and you can hear power going to motor, soliniod on starter motor or what?????????????
  24. #24
    wrx884's Avatar
    Mar 2006
  25. #25
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    hmm whats wrong with this quote? Have you worked on all four of those cars previously??
    Take it to a mechanic get it checked out then fix it yourself.
  1. Sick, sick dirty bastards
    By DannyboyDS in forum The Pub
    Last Post: 02-03-2009, 07:50 PM
  2. just sick of it
    By skweek in forum The Pub
    Last Post: 21-03-2007, 08:53 PM
  3. sick dog
    By bangers in forum The Pub
    Last Post: 15-10-2006, 07:08 PM
  4. Car very sick...
    By Lish in forum General
    Last Post: 14-12-2005, 04:14 PM
