Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By TonyJZX
Thread: clunking noise from drivers side (rear) under acceleration
    VT II SS 5.7/6sp manual
    May 2011
    Default clunking noise from drivers side (rear) under acceleration
    Hey there
    My 99VT SS 5.7 6sp manual has a loud clunking noise that sometimes shows up under 'reasonable' acceleration. Sounds like something knocking around in the boot (but its not!!)
    Also sometimes jumps out of first gear when pulling away. I think the clutch has a pretty high bite point but as its my first commodore I dont know if thats the norm'
    Any ideas???
    VT SS 5.7
    Mar 2005
    Goulburn
    Hi mate, as for the car jumping out of gear that could be your clutch not engauging proply,i know after i had my exedy HD clutch put in the problem has never been back.
    And the knocking noise had me confused for months lol, for me it was 3 things
    1)the plastic holder for the jack in the boot was rattling around
    2) the screw in pin for the spare tyre
    3) rear link pins and rear control arm bushes were shot
    Hope that helps mate
    Real cars don't power the front wheels, they lift them
    VX II Acclaim 2002
    Jun 2011
    Pacific Pines
    I had the exact same thing but with an auto, took it to a garage and ended up having the engine mounts replaced, after that it was completely fine and the clunking noise was gone.
    not saying it's definitely that but could be
    Commodore M6
    Jul 2010
    East Coast
    i have the same thing in my car
    but not under full hard acceleration but only under partitial acceleeration and sometimes under engine braking
    i'm thinking its something expensive so i'm ignoring it
    car
    Jul 2006
    greensy, melb
    being a manual i will put my money on it being the uni's in the tailshaft, when you are coasting along sorta 'jab' at the accelerator pedal and whenever you jab see if it clunks
    "A life lived in fear is a life half lived"
    Commodore M6
    Jul 2010
    East Coast
    but what puzzles me is if i fully hit it hard there's no noise
    i think this is because when you cane it, the shaft and everything is under stress so it's all under tension (no movement up and down?)
    when you only use partial power there's a bit of slack? i dunno
    otherwise my manual and clutch is both ok for a 10yr old that's been hit too many times
  1. Rear clunking/cliking noise with vibrations VT rear end
    By BalooVR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-08-2010, 11:17 AM
  2. Rear clunking/cliking noise with vibrations VT rear end
    By BalooVR in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-08-2010, 11:37 PM
  3. VL body 12mm lower on rear right side (drivers side)
    By ewan in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-03-2009, 02:07 PM
  4. clunking noise coming from the rear?
    By mr_clubby96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 09:48 AM
  5. clunking noise from the rear of the car
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2006, 06:29 PM
