Results 1 to 5 of 5
Thread: Belt and pulleys for Gen III
    VT SS S2 Gen3 and VZ Exec.
    Jan 2011
    Cool Belt and pulleys for Gen III
    Hey guys, my gen III's belt/pulleys makes an awful chirping sound particularly when its cold but to a lesser degree even when hot, does anyone know the best place to get a good price on a complete sepentine belt/idler pulley/tensioner pulley kit? or do they only come separate? I'm assuming I replace the entire pulley(s) rather than press the bearings out?
    Cheers n beers.
    VX SS T56
    Feb 2006
    you could also try taking the pulleys off and packing with grease again.
    I took mine off and used a small screw driver to pry to bearing covers off. There was absolutely no grease in them , just a black shitty residue which was one the factory grease im guessing.
    It probably worth looking at this first. I changed all my belts as i though this was the problem, turned out to be the bearings chirping.
    Most annoying sound in the world!
    VX SS - Twin 2.5 cat back - MAFLESS Tune - MCAI
    Jan 2011
    Yeah its a really sht sound huh! it actually sounds like something is about to let go when its cold sometimes, ive had the pulleys and belt off a couple of times and I tried working some oil into the bearings and this does quieten it all down for a few days but it comes back, the belt doesnt squeal but its very cracked with the odd chunk along the edge of the grooved side and i can actually feel the tiniest bit of play in the tensioner pulley bearing so i kind of figure the best option is just to replace the lot, prying the covers off the sides of the sealed bearings to repack them with grease will only lead to them wearing at an even faster rate once they are open to dust anyhow, indecently are you still running those same bearings? how long have they been going with the seals off?
    VX SS T56
    Feb 2006
    Quote Originally Posted by Anglosaxon View Post
    I did not leave the seals off. I repacked with grease, then put the seals back on.
    YOu just need to be careful taking the seals off so you dont ruin them.
    I have been running the bearings for about 10,000kms since repacking and are still quiet cold or hot.
    Jan 2011
    Sorted, just went and got the lot for $102 at repco
  1. Replacing idler pulleys and fan belt??
    By strikewon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2010, 06:22 PM
  2. Replies: 3
    Last Post: 02-02-2010, 04:25 PM
  3. Naturally aspirated V6 accessories belt versus L67 supercharger belt
    By VSSECO in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2009, 09:23 AM
  4. VX V6 Idler pulleys / Drive belt
    By glenward in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-05-2008, 07:25 PM
  5. Drive belt noise after new pulleys
    By hN! in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-04-2008, 01:47 PM
