Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Like Tree3Likes
Thread: Help!!!
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    Default Help!!!
    I was driving home from work the other night and heard a quite large bang. I then proceeded to look under car and found nothing seemingly wrong.
    Had the car towed but it's still not working. I cant see anything wrong with it though>?? I post some pictures you help?
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Looks fine to me, Have you tried checking the fuses?
    Mat
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Sabbath''s Avatar
    Jul 2006
    Why would i check fuses? The tyre pressures are fine!
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by SabbathSS View Post
    Maybe it's worth resetting the ECU?? I know somethimes mine has issues like that.
    Mat
    car
    Jul 2006
    greensy, melb
    just put a bit of air in the left hand front tyre?
    "A life lived in fear is a life half lived"
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    Bro your car is fine aye.
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
    Sabbath''s Avatar
    Jul 2006
    OK! I try now! Thanks!
    Although im worried the microwave might shrink it?
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    car
    Jul 2006
    greensy, melb
    some_guy's Avatar
    VR SII Exec.
    Apr 2009
    brisvagus
    but on a more serious note....... i think your oil might be low
    97 WRX AWD
    car
    Jul 2006
    greensy, melb
    some_guy's Avatar
    VR SII Exec.
    Apr 2009
    brisvagus
    So your telling me he's not running enough boost?
    97 WRX AWD
    car
    Jul 2006
    greensy, melb
    had a boost the other day, was good
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Ok, by the looks of it, Your petrol tank is empty. Do you have fuel? Have you checked to see if your injectors are moving?
    Mat
  15. #15
    Sabbath''s Avatar
    Jul 2006
    This no help. I look up "V-Tec" and all i get is some silly shopping trolley. I have VT...not ladies drift machine
  16. #16
    hakhawk's Avatar
    Jan 2005
  17. #17
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
  18. #18
    ClairBear's Avatar
    ClairBear is offline Make the stupid stop!
    VE Omega / Hyundai Getz
    Nov 2003
    SA - The Murder State
    The freps is broken.
    Quote Originally Posted by commodore1310 View Post
    Ok, once again ive run aground with a bunch of elitist PRATS who think they know it all, stuff your cars and stuff your forum!
    Quote Originally Posted by one_and_only2004 View Post
    No, driving a v6 engages GOD MODE. Please don't continue the argument...
  19. #19
    edals's Avatar
    edals is offline Blues Brother # 1
    VY 2002 Wagon, VX 2001 Sedan
    Sep 2008
    QLD/NSW Boardish
  20. #20
    WHII Statesman
    Sep 2006
    Geelong, VIC
  21. #21
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    epic neutral dump LOL
  22. #22
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Ah, I have seen this problem before. They call this a female diff and shaft combo. Tends to just explode whenever it feels like it and usually the only way to fix it is to throw money at it. From experience it doesn't take much to set them off.
  23. #23
    Sabbath''s Avatar
    Jul 2006
    Quote Originally Posted by delcowizzid View Post
    Neutral Dump??? Is this a bad thing?
    "All I do is put it in neutral and rev it like BAM BAM BAM BAM BAM BAM BAM BAM then select D for maximum respect" - I thought it was a good thing?
    So if i reset the ECU and check my oil level it should be OK?
  24. #24
    car
    Jul 2006
    greensy, melb
    by checking your oil level i hope you do it right or you could get into problems, take the cap off up near the top of the engine (big black cap) and fill till you see the oil come to the top but stop before it overflows, replace cap and your done
    also resetting the ECU actually retunes your car and you should expect to see an extra 20-45hp
  25. #25
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    Quote Originally Posted by kniever View Post
    make sure you use olive oil too, its super synthetic
    If it isnt tuckin, it must be suckin
