Results 1 to 7 of 7
Thread: ABS module fault
    VX SS
    Jun 2005
    Default ABS module fault
    Hi everyone
    With the common ABs module fault on the VT-VX, are the normal symptoms that the abs, traction control light appear with a error message on the dash?
    When the abs module is disconnected does it also disable the cruise control and air conditioning along with abs and traction control?
    Is there anything major that can go wrong if left disconnected for a while?
    ashbox's Avatar
    ashbox is offline 6 speed
    VZ SS 6 Spd
    Apr 2007
    The Car
    well for starters your insurance would prob be void, abs may not work and yes the normal symptons are the abs, trac and low trac lights coming up on the dash..
    i had to replace mine a couple of months ago
    Chev badges are an instant fail
    VX SS
    Jun 2005
    I dont plan on leaving it for a long time, Im looking at a car that has the issue with the abs module and its been driven around currently like that.
    ashbox's Avatar
    VZ SS 6 Spd
    Apr 2007
    The Car
    well it cost me 600 for mine to be replaced and codes to be cleared
    VT Calais
    Mar 2009
    SA - Victor Harbor
    get one off ebay, cost me 70 bucks to fix it and has never been better, was a simple 15min job to fix too
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    I think mine cost about $150 for a fixed one from eBay, only took a few minutes with a torx screwdriver to swap.
    Ronald Reagan (1986)
    1997 Vt GTS Build 78
    Aug 2009
    East Gippsland
    And That is the Fault in a Nut Shell...........First generation of the Traction control is plagued with Faults, everything from troughing engine lights, to just non responsive, and refusing to be turned on/off
    If you do your research you will find a revised part number for your abs module.....This fixes known issues and updates programming within the unit.......2 distinct parts number, one is the faulty obselete model, the new one is the upgrade......
LinkBacks (?)
  1. 01-04-2012, 10:06 PM
  2. 08-03-2012, 10:30 PM
  3. 14-02-2012, 09:27 PM
  4. 26-11-2011, 04:01 PM
  5. 26-10-2011, 10:00 AM
  6. 12-09-2011, 04:06 PM
  7. 04-09-2011, 08:26 PM
  8. 18-08-2011, 10:50 PM
  9. 08-08-2011, 02:21 PM
  10. 07-08-2011, 05:29 PM
  11. 22-07-2011, 07:52 PM
  12. 07-07-2011, 12:49 AM
  13. 23-06-2011, 10:56 AM
  1. Engine fault light comes on and stays on but fault code says no fault?
    By hildahoop in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2011, 05:46 PM
  2. interchaning Vy s1 berlina climate control panel/module with VZ module
    By mudmutt in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-04-2010, 02:54 PM
  3. ABS module fault, or,...
    By Statesmad in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-10-2009, 06:41 AM
  4. ABS Module Random Fault
    By mopoke in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2008, 03:40 PM
  5. FS [VIC]: power arial module and centrol locking module
    By georgeonboost in forum Parts And Other Items For Sale
    Last Post: 24-09-2008, 06:41 PM
