Yes Always
Yes Most of the time
Yesterday i drove to the shops and the car was fine ran beautiful,when i come out of shops and started the car the radio was not working and it needed the code to be placed, so i reset code,and then last night i went out car was fine radio was working,,as i pulled into my driveway the car stalled and i lost all power,so i left it where it was and then attempted to lock it with remote nuthin happened so i placed key in door and it still would not let me lock doors, so i attempted to start car again and nuthin not even a light on the dash or a murmur from engine, so i left it, now next morning i come out and attempt to start car again and it clicks over first turn all power is back and i had to reset radio code again , but car drove fine and started and stopped several times during the day and then tonight it does the sam all power is lost as i stated above,can someone plese offer me any advice to may be the problem and i what i may need to be fixed, Thank you all help is much appreciated
Check that the battery terminals are clean and the clamps are tight.
MY RIDE
Also have a look where the battery cable is bolted to the starter motor. It is a common problem on the V6 for the nut on the starter motor to come lose .I had a similar problem , car would turn a couple of times on the starter then would struggle to turn and sometimes just cut out when driving .
Thank you, i will have look at those this morning![]()
Hi thanks for advice, however the car is on not co-operating..it started ok comming home from work last nite and i had all power and was fine until the high beam lights started comming on and off on their own, the car got me home and locked fine, go out this morning and i have nuthin no power the doors wouldnt even unlock using remote or the key. I waited 2 hours went out to try again the doors unlocked using the remote and all power was there and car started first turn of the key, i cleaned the battery cables and placed on tight and i checked for teh area where dayvo suggested all seems fine, i am guessing with the high beams comming on by themself its definately electrical, any suggestion on where i should start would be hugely appreciated.Thnks again
Rod
Rod
Clean the battery terminal with 40 grade sand papper make sure that the connection are nice and clean.
Also check all the earthing points clean the terminals and the surface. Check the earth strap from battery to body/engine.
Also check behind the alternator positive battery wire from the battery to the alternator. These become loose.
The high beams coming on by themselves could be a faulty indicator stalk.
MY RIDE
