Results 1 to 8 of 8
Thread: Vx Auto Tranny ####ed?
    VX Acclaim
    Apr 2010
    Default Vx Auto Tranny ####ed?
    hey guys the other day i was driving home from work in peak our traffic through melbourne and all of a sudden my tranny would #### up. it would stay in 1st ttill about 5kRmp and the and then when it changed to 2nd it was as if it was a manual and i dropped the clutch on it. same thing happened with 2nd to third.
    So i pulled over and checked my tranny fluid and it was fine.
    could this mean my autos gone?
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    perhaps not.my transmission was supposedly r.s.about 50,000kms ago cos it was changing gears at anywhere from 1800rpm to 4000rpm,sometimes with a scary clunk similar to what you've described.Believe it or not it turned out to be just a tuning issue.I bought new (genuine) plugs,leads and a coil pack and it was (and still is ) fixed.I mean so fixed ,that included in the 50,000kms since it was stuffed!!! was a trip to darwin towing a 4.6m tinny (fingers crossed eh)
    VY Executive S2/ VY SS 6sp
    Jan 2011
    Western Australia
    check fault codes . i had a vt do something similar it was a maf fault but it could also be a speed sensor or tps fault.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    vn hsv wagon
    Apr 2011
    Frankston
    VX Acclaim
    Apr 2010
    Aug 2004
    Quote Originally Posted by HarroVX View Post
    Tps?
    yeah checked the oil while it was idling in park. oil was fine.
    Throttle Position Sensor. The PCM uses this sensor to tell the auto trans when to change gears. If it's faulty you get changes at higher than normal revs (even when you back off the throttle) and harsh gear changes. Easy and cheap to replace.
    Attached Thumbnails Attached Thumbnails Vx Auto Tranny ####ed?-vx-v6-tps-remove-replace.jpg
    VX Acclaim
    Apr 2010
    sweet as thanks mate.
    looks pretty simple, ill change it and see how we go.
  1. WTB vl auto tranny
    By SthEastCustoms in forum Swap / Wanted to Buy / Trade
    Last Post: 20-04-2007, 05:59 PM
  2. v6 auto tranny
    By Nathan72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-08-2006, 12:52 AM
  3. vl na auto tranny
    By sed8 in forum Parts And Other Items For Sale
    Last Post: 06-04-2006, 05:21 PM
  4. auto tranny..
    By rattattack1313 in forum Parts And Other Items For Sale
    Last Post: 06-08-2005, 06:36 PM
