Results 1 to 6 of 6
Thread: Cam Spec - Yes another one
    CV8 Monaro & VE SV6
    Sep 2009
    Default Cam Spec - Yes another one
    Anyone tried this cam before? Any good? Suits LS1
    Comp Cams
    Hyd Roller
    Lift @ 1.7:1 - .534/ .537
    Sep 112°
    IN 224/ EX 228
    Range 2000-6800
    I think GM Motorsports has something similar in the torque master.
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    sounds like a mild cam, you would need a stallie though
    If it isnt tuckin, it must be suckin
    Aug 2004
    imo id go 228 228...
    although maybe look at 219/227 - 112 seems like an interesting stick... my pick would either be
    228 228 112 or 219/227 112 or there abouts... depends what you want from the car.
    imo going slightly small cam is going to be alot nicer to drive live with and have the low down grunt and mid range that would chop the larger cams
    CV8 Monaro & VE SV6
    Sep 2009
    CV8 Monaro & VE SV6
    Sep 2009
    so cams on the way. Any comments on what stallie I should be lookin at? I was thinking 3000rpm?
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    3k is a good size man. fairly streetable. obviously its best to match it to the cam, when you get the cam tuned the tuner will be able to tell you where the torque is and match one up for you
  1. L67 Spec ???
    By sixshooter in forum V6 Development And Modification
    Last Post: 19-11-2011, 10:21 AM
  2. VN cop spec cars
    By PietroChocko in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2009, 01:21 PM
  3. CAS bearing spec
    By vlrad in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-08-2005, 01:49 AM
