Results 1 to 7 of 7
Thread: 99' VTII Power Window Question
    99 VTII Berlina
    Dec 2008
    Default 99' VTII Power Window Question
    I have an issue with my front passenger window. I had a look and the black piece that is attached to the front of the window that slides within the window guide has come off. Has anyone had this issue before or knows what is involved in fixing it?. Does it require me changing the glass?
    Proud to own and drive a aussie machine.
    Long live holden..drive on.
    Killr6's Avatar
    Killr6 is online now on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    Quote Originally Posted by SoundGuy_025 View Post
    little confused here, but by the sounds of it, its the little rubbery pieces that rub against your window when you wind it up??
    99 VTII Berlina
    Dec 2008
    Quote Originally Posted by DanLucas View Post
    Nah, its a power window. Inside the door there is a aluminum slide at the front of the door. On the front edge of the door there is a black metal piece that is normally attached to the window that slides in the aluminum slide. This has come off. So as it goes up, it jumps out of the slide and misses the slide going down.
    1997 Vt GTS Build 78
    Aug 2009
    East Gippsland
    Sounds like the slide has been damaged...Believe it or not when these are put back together people do em up to tight without spacers and then the Bolt marks the rails, Jambing the glass, or popping the rails......
    Easy fix go the the wreckers and get an inner rails, replace the lot, sould be less the 1hr to do job, aluminium rails can be romoved out of door, and replaced independent of the glass, and regulator.....easy job
    99 VTII Berlina
    Dec 2008
    Quote Originally Posted by nitrowarrior View Post
    So your saying the black piece that moves inside the aluminum slide is coming out because the aluminum slide is damaged?. Is it a case of putting the window all the way up, and undoing the bolts to remove the aluminum slide, is this correct?
    Aug 2009
    East Gippsland
    yep, thats is about it....you will feel when the aluminium slide is free, it can be released from rubber and it will slide out upwards....Check for damage to the slide rail. if damaged replace...When replacing, MAKE SURE that the locator Bolts DO NOT Tighten into rail. use a suitable amount of washers to help to facilitate this.... ..this is how the damage is done......the slide is attached to the black piece, high possiblity of contecting areas being damaged or broken, suggest that you source a replacement Part
    99 VTII Berlina
    Dec 2008
    Ok, thanks for your help I will give it a go.
  1. vt power window question!
    By andrew_oc42 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-12-2010, 11:59 AM
  2. Power Window question
    By commwagon in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2010, 09:28 PM
  3. Power window question
    By coolngroovy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-12-2008, 12:07 PM
  4. power window question
    By crav_vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-05-2007, 12:59 PM
  5. power window button VTII
    By scbh81 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-12-2005, 05:53 PM
