Results 1 to 2 of 2
Thread: Coolant temp and o2 sensor?
    VT COMMODORE EXEC 9C1
    Sep 2005
    Default Coolant temp and o2 sensor?
    Howdy,
    Does anybony know what the resistance should be between both the coolant temp sensor and o2 sensor? I can't find it anywhere on here!
    Thanks
    Steve
    VX Calais ls1
    Sep 2005
    The following are specs for the ls1 motor. May be similar for v6 but maybe not.
    The temp sensor:
    Low temp = high resistance 29k ohms @ -20 degrees
    High temp = low resistance 180 ohms @ 100 degrees
    The oxygen sensors are not thermistors like the temp sensor therefore they are not polled on their resistance value by the pcm. When @ operating temp they act as voltage generators, producing a rapidly changing voltage between 10 - 1000 millivolts depending on the level of oxygen detected. It is the voltage that is polled by the pcm.
  1. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 04:08 PM
  2. where is the coolant temp sensor?
    By 300zx in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2008, 10:01 PM
  3. where is the coolant temp sensor??
    By muney in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2007, 12:43 AM
  4. Coolant temp sensor
    By v8bike in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-06-2005, 07:05 PM
  5. Coolant Temp Sensor
    By kurtbarker in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-04-2005, 04:47 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
