Results 1 to 8 of 8
Thread: latly been getting a rattle from around gear stick area
    vx ss
    Jan 2011
    whittlesea
    Default latly been getting a rattle from around gear stick area
    i have a manual vx ss, and the past few weeks i have been getting a rattle from some where around the gear stick, it only happenes at 3500 when im over taking a car or trying to get to speed quick!
    i have taken everything out from the car, no luck
    i have pulled the gear boot up and had a feel around still can't feel anything
    the only thing i haven't done is pull up the white rubber boot ( coz i don't no how to?)
    any ideas would be great it sound like a loose washer thats vibrating
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    apparently its the gear knob on the 6 speeds, ive read it alot, and mine is exactly the same, hold the knob while your giving it some beans to see if it stops.
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    This is very common on the 6 speeds, it happened on mine (for 4 years) till i got a ripshift, not really much you can do about it.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
    vx ss
    Jan 2011
    whittlesea
    thanks, but its not the knob its in side the console some whrere under the white rubber boot. i spoke to holden and the guy told me you have to take the center console out to get the white rubber boot out
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Gearshift Knob Rattles Gen III Manual - The gearshift knob may vibrate to the point where it can generally be heard in 3rd or 4th gear at wide open throttle between 2500 to 4000 rpm. This condition is a result of excessive clearance between the shifter knob and the shifter lever. From March of 2002, gearshift knobs were glued on.
    Gearshift Rattles Gen III Manual - Under certain driving conditions some VT's may develop a rattling gear shift lever. This condition is different to gear knob rattle. The cause of the rattle may be due to excessive clearances in the remote shifter linkages. A revised remote shifter was introduced late 2003 to eliminate rattles
    Hope that helps must be the 2nd problem as you said it wasnt the gear knob.
    Buy the sounds of it you need a new shifter, may as well invset in a ripshift.
    vx ss
    Jan 2011
    whittlesea
    very very helpful, mm where to get a ripshift! are they any good? can any mechanic install one?
    DLFHUB666's Avatar
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    You can get a ripshift here: HOLDEN HSV VY VZ VE Rip Shifter T56 Ripshifter short | eBay
    Yes any decent machanic should be able to fit one it comes with DIY install papers.
    they are worth more than there weight in GOLD.
    vx ss
    Jan 2011
    whittlesea
    i spoke to gm motosport and he told me $670 supply and fit
    will be getting one when i do my tax!
    its not bad for the gearbox to drive around with rattly linkages? it only happens when i punch it to about 3500 rpms
  1. [SA] HSV VZ VE gear stick/ boot
    By BLOWN R8 in forum Parts And Other Items For Sale
    Last Post: 28-10-2009, 10:40 PM
  2. rattle in engine area...getting worried
    By salty in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-04-2009, 03:33 PM
  3. Gear stick
    By REVDUP in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-05-2006, 08:11 PM
  4. gear stick
    By MELBOURNE DISASTER in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-01-2006, 09:13 PM
  5. Anyone Know Where To Get A New Gear Stick?
    By DavidPartay in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-02-2004, 12:25 PM
