Results 1 to 3 of 3
Thread: VT SS, weird highbeam light fault, rear passenger door is stuck closed...help!
    VY 3.8ltr ute
    Jun 2010
    Default VT SS, weird highbeam light fault, rear passenger door is stuck closed...help!
    Hey guys
    first off, my highbeams randomly come on at night when im driving around and its becoming a nuisance since it makes me look like a dick head high beaming random people. Could it be the stalk on the steering wheel? thats what i have been told and i was wondering if its an easy fix if so can anyone walk me through it please. Otherwise any other suggestions to this problem could help.
    Second, my passenger side rear door is stuck closed and does not want to open at all. ive opened up the inner door handle and tried pulling on the inner wire but to no success, the lock isnt even connected and i think it might just be the mechanical lock thats holding on.. what can i do??
    Tuned VX SS
    Jun 2010
    a stalk is a quick easy change, if your thinking its down that track, grab one from a wreckers.
    unscrew the steering wheel shroud, the stalk slides out and you just have to disconnected the wiring. slide in the the new one and your done.
    however its obviously a wiring issue, so it may or may not be within the stalk. defidently a good starting point though.
    as for the door........ not my thing, try jaws of life
    Killr6's Avatar
    Killr6 is online now on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
  1. Help! rear passenger door stuck in dead lock
    By darkclaw in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-08-2011, 11:16 PM
  2. vt highbeam fault
    By andrew_oc42 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-12-2010, 03:14 PM
  3. front passenger door stuck locked
    By Shell77 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2010, 12:27 PM
  4. VX deadlock stuck on rear passenger door
    By litchy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-08-2010, 11:23 PM
  5. Small light above rear passenger door
    By toey in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-09-2009, 08:03 PM
