Gear Engagement (Gen III Manual) - Some VT's may have trouble selecting reverse gear, or the selector does not go into reverse completely. When the clutch is released, grinding of the gears may be heard if reverse isn't fully engaged. The gear selector may also need to be physically held in reverse to use the gear. A possible cause can be a circlip missing from the forward pivot of the shifter rail. A missing circlip can allow the gearshift pivot pin to partially disengage and become loose, making gear selection difficult.
If excessive effort is used for gear changes, the Remote Shifter Mechanism front pivot ball may dislodge from the nylon retainer. If the pivot ball dislodges, no gear selection would be possible. A metal reinforcing plate was introduced to prevent the ball from dislodging
Might be part of the problem.
Take it easy...But do take it...
Do not argue with an IDIOT.
He will just drag you down to his level an beat you with experience.
Some people take me the wrong way, Like smacking up Marijunna.
