Results 1 to 2 of 2
Thread: VT Stalling
    SV666's Avatar
    SV666 is offline The Commodore Enthusiast
    VE SV6 SIDI
    Feb 2010
    South Morang
    Default VT Stalling
    Hi all,
    My mum has a 99 VT Acclaim and for bout a month I have been hearing that when she takes a right hand turn specifically on a round about whilst turning if she doesn't apply enough acceleration the car stalls forcing her to move out of anyone's way safely to stop so she can restart the car again. She does have plenty of fuel on board so I have ruled that out I'm thinking maybe fuel line? the pump was changed 2 months ago so I'm not too sure whats going on here.. This actually happened about after a week or so after the fuel was changed. Also she gets a grinding noise that vibrates through the cabin when the brake is applied.
    Any info on these symptoms would be much appreciated.
    Quote Originally Posted by kuzman89 View Post
    I heard the V8 badges give it an extra 50hp!
    SV666, I was wrong, the V8 badges... THEY DO NOTHING!
    VT Series 1 V6
    Jan 2008
    Hi mate,
    Stalling on a turn usually indicates the fuel pump is on it's way out. Was it replaced with a new one or a second hand? We have had people on this forum replace fuel pumps and the new ones have also been faulty. If it's new and working, check the fuel pump relay (in the engine bay), or there could be crap in the fuel line. Was the fuel filter changed at the same time as the pump?
    As for the grinding when braking, I would check the pads to make sure they're good. If they are good, maybe warped rotors (does it vibrate?) or wheel bearing. Quite often the simplest answer is the right one.
    Good luck.
  1. Stalling VP
    By 889bhp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2010, 02:40 AM
  2. VR Stalling
    By Kovacic_VR95 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2009, 05:02 PM
  3. Stalling
    By robcom in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2006, 09:52 AM
  4. Stalling VN PLZ help
    By porkkhunt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-03-2006, 07:38 PM
  5. Car stalling
    By kopper69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-03-2006, 01:25 PM
