Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By Trayner
Thread: l67 supercharger onto 3.8 n/a v6
    88 VL Turbo SL and 86 VL SL
    May 2010
    VIC
    Default l67 supercharger onto 3.8 n/a v6
    Hey there i have a 99 vt v6 and i am considering putting on a l67 supercharger on it.
    Besides the blower and the fuel rails and accalerator cable braket,injectors what else is involved ?
    Do you need any special wiring for the l67 blower to work ?
    And with the ecu side off things do you need to put a l67 ecu in and would it be as simple as plug in and play.
    Will it bolt straight on or do you need l67 heads aswell ?
    Modifying a car is like a drug once you start you cannot stop
    Holdens if your not in one your behind one
    03 VY SS 5.7L M6
    Feb 2009
    Enoggera QLD
    As far as im awhere the l67 has a different, stronger bottom end and it also has a different compression ratio as for the ecu side you could get yours tuned to suit the blower or if u got a l67 ecu it would still need to be tuned depends on comp and differences between the ecotec and l67
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Step one: search L67torque.com
    Step two: there is none
    That website will tell you everything you need to know for that kind of conversion.
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    car
    Jul 2006
    greensy, melb
    injectors are in the heads on the l67 so you will need heads too, bottom end was the same except different pistons, also dont forget you will need the extra pulleys for the charger belt too
    "A life lived in fear is a life half lived"
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    what is the actual difference in the bottom end of the two engines? and im talking just the block. is an L67 block actually any different to an NA block?
    wraith's Avatar
    wraith is online now Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    You can pick up a complete L67 with harness for about 2.5k
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    hit up L67torque.com , I was going to buy the charger off ebay , but after reading a bit the stock bottom end of a ecotec can only do minimal boost from the eaton blower were as a l67 block you can mod it up to like 20 psi before it blows
    VS Stato l67
    Mar 2009
    Melb
    Quote Originally Posted by klampy View Post
    L67 has lower compression ratio and I think also stronger piston crown, and stronger rods.
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    yea i knew that. lol.
    i had a look on L67 torque and between the two engines, the block is the same, the crank is the same, and the cam is the same just on different timing, and the heads are also the same, bar the injector bosses being drilled out.(but that is the only difference.)
    so the rods and pistons are different to allow for a lower compression, with the later models getting a coated piston for strength.
    VT 2
    Nov 2008
    Problem with tje L67 blower is that it dumps very hot air into the heads. This increases the chance of pre ignition. Thats why the L67 block has dished pistons for a lower compression ration.
    L67 Bottom end is substantially stronger. That being said - can get up to 10PSI on a std L36 without damage IF (important IF) you keep your intake temps cool, using something like a Raport of a PSI centripetal blower, rather than a screw type.
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    Quote Originally Posted by Tsunamix View Post
    the only parts that make an L67 block strong are the Rods/pistons. everything else is I D E N T I C A L.
    zapper-l67's Avatar
    zapper-l67 is offline LS# Eat One Today...
    VX Calais
    Jan 2010
    Western Vic
    The difference between a standard v6 l36 and a Supercharged L67
    Rods - Larger rod which is stronger. The gudgeon (wrist) pin is also larger.
    Pistons - These have a coating on the top of the piston. They are also larger in the dish, which drops the compression to 8.5:1
    Heads - The heads on the Pre VX Ecotecs are identical to the L67s. However, the L67 heads have a hole drilled into them for the injector. This hole is drilled into a boss that encroaches into the inlet port. The post VX2 ecotec heads (from what I can gather) do not have this boss. They have a clean/straight inlet port.
    Any pre VX Ecotec head can be turned into an L67 head with the right drill bit and the hole drilled at the correct angle.
    Balance shaft - The L67 balance shaft is weighted differently to the Ecotec
    Flex plate - The L67 Flex plate is balanced differently to the Ecotec Flex plate
    Harmonic balancer - The L67 HB has an extra set of grooves for a second belt (the blower belt) It is also balanced differntly to the Ecotec HB.
    The L67 HB and flex plate have to be used together.
    Coil Packs - They are a higher voltage in the L67 compared to the Ecotec.
    Cam gear - The cam gear for the timing chain has a different orientation to the ecotec cam gear. I believe I worked it out to be about 2 degrees. This differetiation retards the cam gear 2 degrees.
    Other than that, they are basicly the same. the blocks are the same, the crank is the same except for manual ecotrec cranks. They have an extra dowel hole in them or something.
    The converters in the L67s have a 2600 factory stall and they also have heavy duty lock up clutches. Where as the ecotec converter is smaller and has an 1800 stall.
    Other than that the L67 and ecotec boxes are basicly the same.
    This is the sort of stuff that happens when the kids get into Dads tool box over weekend.
    Money will be spent, Dreams will be shattered, Lessons will be learned, and a wealth of information will be gained.
    May 2010
    VIC
    Ok thanks heaps for that guys. i think i might just go with a full l67 just to do it all right the first time.
    Just one more question is a l67 5 speed manual stronger then a normal 5 speed.
    DLFHUB666's Avatar
    DLFHUB666 is offline Got Milk ???
    vx s1 ss
    Jun 2010
    Nhulunbuy NT
    Quote Originally Posted by M3ZZA View Post
    The l67 as far as i know never came out in manual, auto only.
    Take it easy...But do take it...
    Do not argue with an IDIOT.
    He will just drag you down to his level an beat you with experience
    Some people take me the wrong way, Like smacking up Marijunna.
  15. #15
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
  16. #16
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    yeah there was never a L67 manual, well not that i know of.
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
  17. #17
    zapper-l67's Avatar
    VX Calais
    Jan 2010
    Western Vic
    A good Auto in an L67 is up to a second faster over the quarter than a manual..
  1. Supercharger Oil?
    By substanceVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-06-2010, 02:02 PM
  2. [SA] Wtb: SC14 supercharger and / or VR supercharger kit
    By social in forum Swap / Wanted to Buy / Trade
    Last Post: 12-05-2009, 07:52 PM
  3. Supercharger M90
    By RVN 355 in forum V6 Development And Modification
    Last Post: 09-02-2008, 04:56 PM
  4. Which Supercharger?
    By 253@7k in forum V8 Development and Modification
    Last Post: 30-08-2006, 09:01 PM
  5. supercharger
    By Blue-Chip in forum Parts And Other Items For Sale
    Last Post: 22-08-2006, 12:56 AM
