Results 1 to 12 of 12
Thread: Grinding noise on rear brake rotors
    VX Executive
    Feb 2008
    Default Grinding noise on rear brake rotors
    Heard this gawd awful grinding noise when i pulled into the driveway today. I thought i had ran over a rock. When i pulled up into the garage the grinding sound was louder and seem to coming from the rear. I noticed the rear braker rotor on the driver side had 'abnormal' wear. Looks jagged but not cracked and the other rear passenger brake rotor was looking shiny. Seems to be ok.
    Are my brake pads worn down? What is possibly scraping the brake rotors? Are my calipers stuck together? I took the car for a short drive and the car does feel a bit 'sluggish'
    I'm thinking of disassembling the rear barkes and taking a look. hope its just worn out brake pads. Do I have to skim the brake rotors when fitting in the new brake pads? do i have to change the brake oil too?
    Killr6's Avatar
    Killr6 is online now on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    sounds like you have worn the brake pads out, and when you brake your ####ing your rotor, because there are no pads there so its basically using the rotor as pad.
    dont drive it anywhere but to your local brake shop, your discs will need to be machined and have new pads fitted.
    VX Executive
    Feb 2008
    ooooo...you are 100% right. I'm killing my rotors by grinding the already worn out pads. I'l go check tomorrow for OEM brake pads and skim the rears a bit. How much do i have to skim the rear rotors? 2-3mm? they are fairly thick at the moment
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Are they just standard rotors? Its about the same price to get new ones as it is to machine them, and I know which I would prefer.
    Ronald Reagan (1986)
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    ^ this
    yeah they shouldn't need to much, if the grinding problem has only just started. but when you get the wheel and calliper off you should see how much it needs.
    next time make sure to check your pads every time your service
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I think half the VT VX's i pass sound like their grinding something inside the wheels.. even the hubs go rusty and send back chatter.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    nemesis_adrasteia's Avatar
    nemesis_adrasteia is offline better to reign in hell
    VR accliam, TF gemini, TC gemini, 79 isuzu ute
    Feb 2009
    longford, victoria
    Quote Originally Posted by blacknight View Post
    its hardly worth machining rotors in my oppinion, you lose brake material less rotor to absorb heat=faster brake fade.
    plus the cost of machining vs replacing its barely worth doing.
    "The mind is its own place, and in itself, can make a Heaven of Hell, a Hell of Heaven."
    apparently wasting my time with 97 cubic inches
    milk doesnt come in 1.6 litres
    my geminis
    VX Executive
    Feb 2008
    I havent checked the cost of machining the brake rotors but the thing is...OEM rotors for the VX here will take about a month to be 'special ordered' from Australia. I'm not sure which brake brake rotors are compatible with the VX, so it seems...at least for now...machining seems to be a temporary solution
    VY SS
    May 2011
    Auckland
    You could try pricing aftermarket parts? If it's been grinding with no
    Pad there's a pretty good chance it's already below the minimum thickness
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Where abouts are you?
    Visit my Facebook page
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    I too had a noise suddenly start on my rear left wheel when I braked. Had a look and both pads had detached from the backing plate on that side even though there was still 50% pad left on them. Checked other side and it hadn't detached, but I replaced both sides anyway.
    Have heard two other incidents of this occurring in the last two weeks, from a VS, VT and well mine is VY.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by VYMAD View Post
    What brand of pad is this happening with?I always use ferodo or bendix brand pads and have not had any problems with either one.I go through a set of pads usually in about 9 -12 months as I like to brake pretty hard a lot of the time..
  1. [ACT] WTB: VT Wagon rear brake rotors
    By timtulip in forum Swap / Wanted to Buy / Trade
    Last Post: 05-04-2011, 09:52 AM
  2. Major grinding noise from rear end??HELP!
    By sidrome in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-12-2010, 07:02 PM
  3. VY grinding noise from rear
    By Tammy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-03-2009, 10:23 AM
  4. Rear brake grinding
    By neobristol in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-03-2007, 04:03 PM
  5. vt berlina,97. grinding noise in rear end
    By pebbles in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-03-2005, 01:14 PM
