Results 1 to 24 of 24
Like Tree1Likes
  • 1 Post By acarmody
Thread: does anyone know how to change the rear springs of a vt?
    VT sedan
    Jan 2011
    Lexton
    Question does anyone know how to change the rear springs of a vt?
    Hello all, just a question i have on the rear springs. I want to get pedders touring springs to put in my vt and i was just wondering does anyone have exact steps on how to do this? i've looked around and i know a rough idea on what to do but can anyone help with detailed instructions on the subject? please help me :/
    thanks
    __________________________________________________ __________________________________________________ _________________________
    Dman's vt exec', 19" vanquish rims, Bagged at the rear , custom boot, 2x 12" subs, tv, xbox360, custom purple interior, dash, seats, door trim, tinted
    http://forums.justcommodores.com.au/...-dmans-vt.html
    Future mods: lowered front, Gto Bodykit, 12mm Plenum spacer, 25mm Manifold insulator, Custom CAI,
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    if your not sure a professional would probably be a better choice...
    changing springs isnt an easy task mate...plus if your lowering it a bit you will
    need a camber kit anyways..
    Quote Originally Posted by some_guy View Post
    This posts stupidity makes baby jesus cry.
    My Ride
    currently retrofitting projector headlights
    Killr6's Avatar
    Killr6 is online now on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Quote Originally Posted by DanLucas View Post
    you dont "need" a camber kit, just helps keep your tyre tread longer.
    here mate How to change your suspension/lower your live axle commodore
    but as said go to a pro.
    I think the IRS setup in the OPs VT will be a little different to a Live Axel setup.
    Ronald Reagan (1986)
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    my bad :P
    I recommend it anyway...who likes forking out for rubber all the time lol
    My Ride
    VT sedan
    Jan 2011
    Lexton
    i asked my local mechanic, and he said its not that hard at all, and the guy at Pedders said i might as well save money doing it myself and yer i think it is a different setup to live axel.
    they all just said be careful with the compressed spring but apart from that its very simple, but do you think it isnt quite that simple? sorry to bother you all :/ but thanks for the comments guys
    VT sedan
    Jan 2011
    Lexton
    and yes that is true, but im most probably putting load assist airbags to bring back close to the original height and aren't camber kits designed for the 0-5 degree angle change from wear? but like i said im not exactly sure so thats why im asking
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    i dunno mate lol...
    my mates dad is a front end specialist and he did my missus car and recommended a camber kit..
    she went superlows not sure if that is relevant?
    but if a pro recommends it thats enough for me
    My Ride
    VT sedan
    Jan 2011
    Lexton
    haha true ey? :P but i guess il have a look at how its wearing after i put them in, at pedders they want like 300 for the bags and springs so i thought i might save the 300 and get assistance off my next door neighbor ( mechanic ) if i need help from what they say its not that hard but then again . . .. thats why they are the mechanics and im the driver :P
    Killr6's Avatar
    XR6T
    Sep 2010
    Hervey Bay QLD
    thats the only "how to" on the setup i could find lol.
    they all recommend a camber kit, in the long run it saves you money
    VT sedan
    Jan 2011
    Lexton
    yer thats true :P well for starters i probably wont ill just get them in then save for a camber kit and chuck that in when i say save i am refering to me being 17 and actually needing to save hahaha
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    yeah true...i suppose at the end of the day it is up to you...
    plus if you get it done by a pro you get the reassurance that nothing..
    well nothing should go wrong and if it does..sue their ass!
    My Ride
    VT sedan
    Jan 2011
    Lexton
    haha yer thats true as well :P ill have a chat to pedders and see what they reckon and tips if i do it myself etc and then weigh up the possibilities thanks heaps for the comments
    VX Berlina
    Apr 2007
    For the camber kit I think (not 100% on this) you need some special press machine/tool or something.
    As for fitting VT rear springs. With car on ground, attack spring compressors, raise car up, remove tyre, undo bottom shock bolt, if spring can't be removed as is than tighten the compressors until you can just get it out, reverse to install new ones.
  15. #15
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Tools you will need:
    Trolley jack (can use regular jack but this will make the process more of a pain in the arse.)
    Body stands (Can to it without them, but once again, pain in the bum.)
    Spring compressors (Once again, doable without then but BIG pain in the arse and you're going to need a mate)
    Socket set
    WD40
    4 bricks
    Step 1:
    Park the car on level, solid ground.
    Step 2:
    Bricks behind and infront of front wheels
    Step 3:
    Take the handbrake off. Make sure you do this.
    Step 4:
    Start jacking the car until the wheels are almost of the ground but still touching. If you have a trolley jack, I find the metal diff mount is a good spot. NOT UNDER THE DIFF, but the black hout are the rear of the diff. If you only have your single jack the jack one side. For the purpose of this I will write it up like we're using a trolley jack.
    Step 5:
    Loosen nuts on the wheel.
    Step 6:
    Keep jacking until wheel are off the gound and you can fit the body stand under. Put them where the usual jacking point is on the car. (If you don't have body stands and are using a trolley jack use put something under the car so it doesn't drop as you're going to be man handling it a bit later on. If you are using a regular jack, just put the wheel under the car so if it drops, it drops on the wheel. Using the spare is probably a good idea).
    Step 7:
    Take the wheel off
    Step 8:
    Undo the lower shock bolt. If it's being a bastard, WD40 it, take 5min and try again. If you're still struggling, you CAN unto the top shock nut and drop the shock, but the danger there is that if the car drops the chances of damaging the shock and body are high.
    Step 9:
    Use the spring compressors on the rear spring. One compressor either side of the spring and tighten them evenly. You can apply pressure on the control arm to try and release the spring. I managed to get out FE2 springs in the past without compressors but it was my mate pushing down on the arm and a fair bit of swearing. Which compressors, its time consuming but the spring will come out nice and easy.
    Step 10:
    Once you've removed the old springs, put the new ones in. Changes are the new lowered springs will go in without the need for compressors.
    Step 11:
    Bolt the shocks back on
    Step 12:
    Wheels back on
    Step 13:
    Remove the body stands and drop the car. If you where using a regular jack and only did one side at a time, back to step 4 for the other side.
    Step 14:
    Make sure everything is nice and tight, shock bolts, wheel nuts, etc.
    Step 15:
    Step back and have colourbond moment.
    Step 16:
    Remember to remove those bricks before you decided to go for a test drive.
    In a VT you've probably want to look into a camber kit down the track. VT cambe is mental when lowered. This is something you will need a suspension place to do as unless you know how to properly adjust the kit, it's a waste of time.
  16. #16
    VX Berlina
    Apr 2007
    I had serious trouble with my lower shock bolt last time, I just got my breaker bar, and put the factory jack under the end of it and raised the jack, that sure loosened it. On a side note, a rattle gun raises a jack really fast, LOL.
    Question Jesterarts, I've heard its easier if you can get the compressors on the springs with the car still on the tyres as it means the springs are already compressed, your thoughts?
  17. #17
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Yep, if you can get the compressors on before lifting the car then it would be easier down the track as you would prevent the spring from decompressing in the first place.
    Though good luck with that. I find springs compressor enough of a pest with the wheel off! Maybe doable if you have a pit or ramps, but I can't see this happening with the car just sitting on the ground.
    Also, you want to avoid being too forcefull with the lower shock bolt. If you break it or screw the thread in the cast component, your will be in a WORLD of pain.
    If the bolt doesn't want to let go, the upper nut is a piece of piss to get undone and you just need to be more careful to ensure you don't drop the car as the chases of damaging the shock or shock mount are greater dropping from the top than if you unbolt it at the bottom.
  18. #18
    VT sedan
    Jan 2011
    Lexton
    haha im loving the colourbond moment :P haha and yer thats what i had in mind basically those steps just wanted to clarify so thankyou heaps and heaps for that!! :P and i imagine a rattle gun would lift a jack quite fast :P haha thanks heaps
  19. #19
    VX Berlina
    Apr 2007
    Quote Originally Posted by Jesterarts View Post
    Well it was only my parents car anyway, LOL.
    Damn thing was seized pretty good.
    Quote Originally Posted by DmanVT View Post
    Yep, for really f'ing lazy people like me.
  20. #20
    VT sedan
    Jan 2011
    Lexton
    haha agreed :P well the same principal applies when trying to test start a whipper snipper motor with a drill on the magneto :P
  21. #21
    VX Berlina
    Apr 2007
    HAHA.
    Makes me wonder if you could start an old carby car with a big air hammer on the harmonic balancer bolt?
  22. #22
    VT sedan
    Jan 2011
    Lexton
    haha a big hammer and a quick reaction time to get out of there when it goes haha
  23. #23
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    Holden recommend the 2 point camber kit as the 4 point causes handling unstabilities at highway speeds. VT's have natural wear on the insides of the rear tyres 2 point/4 point kit allows this to be corrected.
  24. #24
    VX Berlina
    Apr 2007
    Unstable at highway speeds? Since when? Maybe at 200km/h a Commodore Boat may not be the most stable thing around, but for 110km/h it will be fine.
  1. [NSW] WTB VU front v8 struts/springs and rear springs standard height
    By dreammist in forum Swap / Wanted to Buy / Trade
    Last Post: 23-12-2010, 11:55 AM
  2. Lowering car, change just springs or springs + shocks
    By wildeagle44 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-01-2010, 06:38 PM
  3. how to change rear coil springs in a live axal
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-08-2009, 01:28 PM
  4. [QLD] swap Solid axle springs for IRS springs for the rear - Goodna
    By Gus The Snail in forum Swap / Wanted to Buy / Trade
    Last Post: 10-04-2009, 07:59 PM
  5. how to change VT springs
    By Joel_91 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-02-2009, 06:01 PM
