hey fellas,
I just got car back from the mechanics with new engine mounts however i'm still hearing a clunking noise occasionally when i turn, I know my linkages are quite worn and will need replacing within 6 months, I'm just wondering if thats whats making the noise? Or is there something else?
If so, is this kit the one to buy?
Holden Commodore VT-2,VX,VY. Sway Bar Link Pin Kit | eBay or... Holden Commodore VN,VP,VR,VS,VT. Sway Bar Link Pin Kit | eBay
Have you had a look on you car to see if you have the 90 degree bend one or not?
Ronald Reagan (1986)
On my vt wagon I know it's the second one you will just have to look yourself to see what one you need.
Just recently one of my rubber spacers cracked and fell out and would rattle when I drove it so I just replaced all the rubbers
im almost sure that the first ones with the 90 degree ball joint werent released until vy, they can be fitted but you would need a vy swaybar, but there is nothing wrong with the other aftermarket links they are a marked improvment on the original sway bar links.
My VX Series 1 has the 90 degree ones.
Ok so i brought the z-shaped links from ebay and they should hopefully arrive this week. I've searched the forums and everyone seems to have different opinions on how to replace them. Can i replace them with the wheels on the ground? Can i jack up one side, take the wheel off and put a stand below the control arm and replace 1 side at a time? Or do i have to jack the whole car up, put stands on either side and replace them that way?
Yes but it's awkwardCan i replace them with the wheels on the ground?
Yes again but it makes life difficult because you have to lever the 'bar down far enough to get the link out rather than having the 'bar freely drop down out of the way. Being able to rotate the wheels on the steering also helps.Can i jack up one side, take the wheel off and put a stand below the control arm and replace 1 side at a time? Or do i have to jack the whole car up, put stands on either side and replace them that way?
Have you read my "How To" on replacing the links?
