I have a VU SS and ever since i baught it the fog lights do not work, when you press the switch the dash light comes on as it should but there is nothing from the lights... i have changed the bulbs and the fuse but still nothing
Any help would be great
Pretty certain you have to have your normal headlight light switch in the parker or headlight position for them to work, have you tried that? I will check on my VX SS, I hardly ever use them but I think you need the switch for the headlights in the parker or on position.
also some time the wires from the fog light earth out on the body theres a clip that they connect to inner guard check if its off that
check to see if ur getting power to the fog light plug first. and make sure you plug it back in tightly
Check out my ride here >>>>My VX Raptor
say NO to chev badges
Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
Have you checked the relay in the fuse box under the bonnet ?
Hi guys i have checked the fuse and relays, i have made sure its in the park position before turning them on and the light in the dash comes on but just not lights... I will check the earth but im certain its fine
do you know how to "bell out" with a multimeter? that can tell you if the wire is broken
