Results 1 to 10 of 10
Thread: [VT] Auto late shifting and high revs
    Olympic VT Commodore
    Apr 2010
    Default [VT] Auto late shifting and high revs
    Hey all,
    Had my vt for few months now and its done 175k however am noticing now that when taking it up to 100 on the highway from 0 it shifts only when it gets up to quite a high speed and engine getting to quite high revs have to usually back foot off accelerator for a milisecond for it to shift.
    Also when cruising sometimes when travelling 100 it will be at 3k revs and have to take it up to 105 for it to shift into highest gear and go back to around 2k revs. Usually is 2k revs when at 100... Is this going to be a growing problem if i dont sort something out- dont like the idea of going higher revs at 100 as will be chewing more fuel...
    Vt Berlina S Pac SII L67 Turbo Project
    Jul 2010
    power button on or off
    power button stretches the gears like a gay
    if its doing it on economical problem somewhere
    try a service
    Sabbath''s Avatar
    Sabbath' is online now Take it out/Take it Back
    Turbo Diesel SR5 Hilux/VH 308
    Jul 2006
    How's the trans fluid looking?
    Quote Originally Posted by ari666 View Post
    i have a proper update for ya:
    sabbath is not fire proof.
    Quote Originally Posted by Reaper:
    cowl on your car is like having the most epic boob job ever and then fitting 4 grandma bras over the top
    Quote Originally Posted by Jecs:
    i dont know exactly what that means, but i feel like i should pull my pants down a lil
    Apr 2010
    Nope power button not on but will keep that in mind, and will check the tranny fluid in the morning. Service coming up in roughly 1000 clicks so could help it out
    Holden commodore VX S Pack
    Apr 2010
    Bacchus Marsh Vic
    Hmm i kind of had a similar problem
    When your car is idling, does it rev a bit faster than normal?
    [SIGPIC][/SIGPIC]
    som
    som is offline
    vt executive
    Apr 2011
    thorneside qld
    don't laugh but i reckon there's a huge chance it's a tuning issue.plugs& leads first,then look at the coil pack (or perhaps just an individual coil )and a service of course Good luck
    vy commodore executive S2
    Jan 2011
    I got a similer problem, got my vy 03 Auto transmission checked and found the tranny pump not working properly and also had a leak , mine was doing the same , with low fluid it cooked the clutch and now he quoted me $650 only for the pump, $1100 for pump and clutch or $1600 for rebuild of the transmission with 12months warrenty.
    Mine has only done only 106000 ks,,am amazed how could holden tranny go bad........
    at the moment am totally confused ,should i get a whole rebuild or just the new clutch. and for you brother would reckon to go to a transmission specialist..
    1995 vs ss commodore
    Jul 2011
    auckland
    Default vs ss trans coolant lines witch is witch
    ive just put a new 6hbd in my ss but need to know witch fitting is a feed line and witch is the return line is the top fitting on trans the feed and the bottem fitting on trans the return? some 1 help
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    When it does shift, are the shifts very hard/jerky - especially the 1 -> 2 shift. If so I would (almost) put my money on replacing the TPS (Throttle Position Sensor). Below are the instructions for replacing the TPS on a VX, the VT shouldn't be too different:
    Attached Thumbnails Attached Thumbnails [VT] Auto late shifting and high revs-vx-v6-tps-remove-replace.jpg
    VX Commodore
    Sep 2010
    VIC melb
    I had a similar problem and one of my ignition leads had completely fallen off. just check them to see if there all secure.
    R.I.P Brocky
  1. vs 5 speed revs up when shifting
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-04-2011, 11:09 PM
  2. VN V8 Auto Transmission Issue (High Revs, 4 gears)
    By 8rody in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2010, 12:16 PM
  3. Auto v6 misses when 75%+ throttle is applied or high revs in neutral PLEASE HELP!! :)
    By shmickmik in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-12-2008, 12:18 PM
  4. revs too high!
    By kwik6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-02-2006, 10:58 AM
  5. revs to high and gears not shifting right
    By timboss04 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-11-2005, 04:35 PM
