Results 1 to 16 of 16
Thread: VT steering wheel clock spring HELP!
    98 VT Executive
    Aug 2008
    Sunshine Coast
    Default VT steering wheel clock spring HELP!
    Hey VT fans,
    I need to replace the clock spring for my steering wheel airbag. Is there a thread on how to do this with guided steps? ...or is it just worth getting someone who knows what they're doing to do it?
    Cheers,
    Joe
    Joe
    [url]www.cleangetaway.com.au[/url[
    Your Professional Car Detailer
    98 VT Executive
    Aug 2008
    Sunshine Coast
    Any one got any advice?
    thanks
    Joe
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I don't know if there is a how to but if you buy a Gregory's manual for around $40 it will tell you how to do it and you won't have to pay someone to do it, and the manual will come handy over and over again. I wouldn't be without one.
    MY RIDE
    vs commodore
    Oct 2009
    Tamworth NSW
    ^^^^ agreed 100%.These workshop manuals are a bible to me,I wouldnt be without mine.They save so much $$$$.
    vt s1 clubsport 5lt 5spd
    Dec 2010
    dandenong
    i got quoted only $280 to fix this by holden ($160 for a new clockspring, and $120 labour). im not sure if you need to get the airbag light reset after changing it, but if so, it makes sense to get it done by holden. as a clockspring is a fairly common wearing part, new is better than second hand. at this price, i would save myself the effort and pay to get it done.
    if you are only new to fixing commodores, the proceedure for doing this job yourself by a workshop manual might be tricky for you. then again, if you are very mechanically minded, you should be fine
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by slowandlow View Post
    Disconnecting the battery before before removing air bags should stop the air bag warning and the need to reset. The prices sure vary from dealer to dealer, I was just quoted $190 by Holden for a new clock spring.
    MY RIDE
    Dec 2010
    dandenong
    190 bucks!!! i musta been quoted an extra 90 bucks sucker tax...
    maybee ill ring back for another quote on the part from another dealership. im thinking im being charged highest for the part, probably labour is a bit much too. shouldnt be 2 hrs for them guys, just one
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    My quote was for the part only so you are doing alright.
    MY RIDE
    Dec 2010
    dandenong
    oh ok. lucky i read it after business hours and didnt try calling to get a better price.... i dont think i woulda gotten anywhere with further discounting
    i may have gotten a few bucks off already ,because i told the spare parts counter, the service guys told me to call them to get the price on the part for them to fit it.
    strange that the holden service guys didnt know the part price automatically when i asked for a quote to fix it. they just gave me the labour price and told me to ring the parts counter and add the price of the part. slackers!
    VX Executive
    Mar 2011
    did this about a month or so ago. easy as to do it yourself, holden will tell you that a mechanic needs to do it as you need to remove the steering wheel. dont bother its easy.
    1.disconnect battery first just to make sure the airbag wont bow up in your face.
    2.remove the airbag from the rear. (with a torx key set)
    3. you will see a single bolt. find the right sized socket and undo it. make sure you get someone to hold the wheel in the straight position.
    4. unclip 3 clips that power airbag horn and steering wheel buttons (if you have them). make sure you look at where you unclipped them from. they need to be tucked away when you put it all back together.
    5. you will see the clock spring pull it out, put the new one in and reverse the steps putting it back together.
    hope this helps mate.
    good luck
    98 VT Executive
    Aug 2008
    Sunshine Coast
    Thanks heaps guys! And thank you Vnathanx for explaining it in great detail. really do appreciate it I just want to be able to get my VT on the market as I am buying a 06 S Thunder
    Joe
    VX Executive
    Mar 2011
    Quote Originally Posted by JoeFish View Post
    nice upgrade yeah its a bit of a pain having to replace it money could go to something better. you look at it and you realise why they break lol
    VE MY10 SV6 A6
    Feb 2010
    Regional South Australia
    I've just had the same problem happen.
    Off the top of his head, the auto electrician said about $300 fully fitted. I then rang around for quotes on the part, and holden is cheapest at $165 for my calais. Went back to the auto, and he said about $260 for the job.
    I'm happy to pay that, as I'm not the most mechanical minded bloke around.
    VX Executive
    Mar 2011
    Quote Originally Posted by burleighboy86 View Post
    its easy peasy do to it yourself mate
  15. #15
    VT Berlina S1 V6
    Jan 2012
    Hey VT fans,
    Cheers,
    Joe
    I wrote this step-by-step with pictures just before, i hope it helps anyone else. You may have to scroll down the page a bit
    How to change the Clock Spring on a VT
  16. #16
    VT Calais
    Aug 2010
    Rofl i payed about 60-70 for mine (VT) fitted it in 5 min after i got home, make sure you dont turn the clock spring when fitting it as it only turns a set amount either way.. If you lived closer id get the part cheap for ya and fit for nothin
  1. How to change the Clock Spring on a VT
    By Thumpin in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2012, 08:17 PM
  2. Can I use this clock spring?
    By qiken in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2010, 01:23 PM
  3. [VIC] WTB Vs Steering wheel Clock spring.
    By TrikkBen in forum Swap / Wanted to Buy / Trade
    Last Post: 04-12-2009, 08:41 AM
  4. F/S VTII Clock Spring
    By ScottB_33 in forum Parts And Other Items For Sale
    Last Post: 14-03-2006, 07:51 PM
