Results 1 to 6 of 6
Thread: vx handbrake problem
    VK ROYALE
    Sep 2009
    Default vx handbrake problem
    i have just finished adjusting my wifes handbrake on her v6 vx, i undid the nut in the car then adjusted the shoes untill the disc could just fit back on, the problem i have is how tight is the handbrake ment to be? should you be able to put it in drive and move the car? i parked it on a hill and the handbrake holds
    just wondering how tight it is ment to hold when your in drive?
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Don't know about trying to test it in drive, but the handle should pull up around 4-5 clicks when handbrake is adjusted properly.
    I don't think it would go anywhere in drive if it's adjusted right.
    VX Calais LS1, VS Calais L36
    Mar 2010
    I'd think if you were able to get the disc back on after adjusting you'd be right. But you can double check by jacking the rear wheels, hand brake off, trans into N and check if there's any drag.
    VP Exec
    Jun 2005
    You should be able to apply some accelerator and have the park brake hold the car.
    It's better to back the cable adjustment off inside the car, adjust the shoes (is it still "shoes" when it's one piece?) inside the disc to give a light drag, then go back and adjust the cable so as to have no free play.
    I would consider 4-5 clicks as too tight. Maybe 7?
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Cheap6's method is the correct way to adjust the handbrake.
    4-5 clicks is about right, can go to 6 if you wanted.
    Visit my Facebook page
    VP Exec
    Jun 2005
    I'll allow 6-7 . As long as it holds the car, looser is better.
  1. VT '99 - Brake/Handbrake Problem
    By ironwool in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-05-2011, 03:29 PM
  2. Problem with handbrake
    By holdensupporter2005 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 15-10-2008, 12:27 PM
  3. vx calais handbrake button problem
    By dijm8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-03-2008, 01:12 AM
  4. problem with handbrake
    By SHAUN2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-07-2006, 11:03 AM
  5. handbrake problem
    By channyb in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2005, 07:58 AM
