Results 1 to 4 of 4
Thread: auto transmission on vx clubby blown?
    HSV VX Clubsport
    May 2011
    Default auto transmission on vx clubby blown?
    hi,
    i have a vx series 1 clubsport 5.7.
    the trans warning light came on, and it has been holding the gears for a while now, and just today it is holding in first gear and reving high so i cant realy take it past 30km,
    please any info on what im up for??
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Have you checked the fluid level?
    MY RIDE
    HSV VX Clubsport
    May 2011
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    You may have a shift solenoid problem - easy and cheap fix. You need to take it somewhere that has a scanner to check what error codes have been logged to be certain of the problem. TPS is also a possibility but wouldn't normally keep the trans in first. Can you get all gears by selecting them manually?
  1. VE SV6 200 H0 Motor Auto 2008 Transmission Change of Auto oil
    By markholland in forum VE Holden Commodore (2006 - ?)
    Last Post: 31-01-2011, 05:24 PM
  2. transmission blown
    By vp_commo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2010, 05:41 PM
  3. Blown vx clubby r8
    By HRDHSV in forum VT - VX - VU - WH - V2
    Last Post: 20-02-2010, 09:55 PM
  4. Transmission is it blown
    By brianbee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2009, 07:05 PM
  5. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
