Results 1 to 3 of 3
Thread: How to replace the Clutch Fluid in a LS1
    Holden Commodore VX 2002
    Jun 2011
    Default How to replace the Clutch Fluid in a LS1
    I want to replace the clutch fluid as it is black and has some lumps in the resevoir!
    Ive done a bit of searching just want to be sure on how its done.
    Is this correct for the LS1??
    " you can do it the same as you would bleed the brakes on the car, its a bit difficult though as there is a small opening on the LHS of the bellhousing. you will need a 1/4 drive ratchet with a 13mm tube socket or a 1/4 ratchet with uni joint and tube socket (could be wrong with the size as i did mine ages ago) and bleed it like you would bleed the brakes. HEAPS easier on a hoist!"
    If not how is it done?
    WHII Statesman
    Sep 2006
    Geelong, VIC
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Replacing the clutch fluid is made a little tricky because of the location of the bleed nipple on the slave cylinder which is inside the bell housing. Best suggestion is to install an Xtreme Extended Clutch Bleeder part number CSCGM011-EXTBL. I purchased one recently from Bursons for $17. Remove the old bleeder by using double sided tape inside a long 7/16" socket (to make sure the old one doesn't slip inside the bell housing). Slide in the extended bleeder and make sure you fully tighten the new bleeder before loosening it slightly for the bleed. It winds in quite a long way. You can then bleed the clutch in the same way as you do brakes - siphon out the old fluid from the clutch master cylinder (I use a turkey baster !!!), mop the remaining junk out of the master cylinder using a rag or kitchen paper, fill with new fluid and bleed. Make sure you keep up the fluid level in the master cylinder because the capacity of the cylinder is only sufficient for about three pumps of the clutch pedal.
  1. Brake and Clutch Fluid Replacement
    By impulsive in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-02-2011, 04:47 PM
  2. changing clutch fluid..
    By MickT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-09-2010, 10:32 PM
  3. clutch fluid on pedal
    By todro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-05-2008, 11:15 PM
  4. How to change clutch fluid
    By newtownbob in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-04-2008, 08:38 PM
  5. Changing Clutch Fluid
    By Johnny_V in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-06-2006, 08:27 PM
