i have a vt v6 executive and i was wondering if anyone has any ideas on what i should do to my exhaust.... ?
dont want it illegal but dont want to over spend either...
i was thinking just a 2 1/2 inch cat back????
any opinions or other ideas?
If it's one thing that gets plenty of talk. it's v6 exhaust. jump on the search tool and they should come up all over the place..
Also youtubtheirer everywhere.. don't worry to much about 2 mufflers or single mufflers. mines got the single muffler and it's pretty quite. actually it'quieterer than my old VP which has a muffler and rear hot dog. that car can be heard streets away.
Originally Posted by Yoda
I can do a Manta 2 1/2" cat back for $220 shipped to your door. Add $385 if you wanted to do extractors as well. You can add a high flow cat as well, but all it will do on a V6 is make it louder, the stock cat flows well enough for the 6. There is no welding required to fit the extractors either, so you could do it all yourself.
Yep, Wildcats, made by Genie. I do these because they are the easiest to fit. They slip onto the original Y pipe, no need to weld flanges on like most other brands.
thanx for ur input guys. spoke to the local exhaust shop and he said he can do a 2.5 catback for 280 supplied and fitted and he reckons when he does it he can leave the rear resinator out....
any advice?
No rear resi, might be to much. Mines a single muffler straight through rear and I truly think its not loud. I even joked about how quiet it is. He said ok. Want me to fit a 3" rear after the muffler, I'm sure you will hear it then.
brooo!!! true flow all the way aha
so what are peoples thoughts on the rear muffler? My V6 VN had one and you could hear it from blocks away, would leaving it off on the VT make it to loud?
It will make it louder, but I dont think it will compare to the noise a buick v6 single muffler would make.
ebay is your best bet, at the end of the day its a v6 all your exhaust is going to do is make noise... mine cost me $50 it's one of the easiest mods and it takes minimal knowledge and not even a full day.. grab a mate, some drinks and play some 104.3 FM and learn as you go !
At least FORD circled the problem
Lukey 2.5" with no rear res, should be 250-300
How does it alter the performance mate?
A larger more free flowing exhaust will change your torque curve (acceleration you feel) through the rev range. It will shift it higher. It will feel like you have lost a bit down low but you will gain more up top. It will also give you better highway economy.
As I said, I can ship a 2 1/2" cat back to your door for $220, very easy to fit yourself.
all good mate got a redback 2 1/2 inch cat back with dual tip fitted for $360 from local exhaust place. thanx for the offer tho
