Results 1 to 4 of 4
Thread: Power Steering Boot replacement & Speedo question
    Phantom Black VT Executive
    Aug 2010
    Default Power Steering Boot replacement & Speedo question
    Howdy,
    I have a tear in my Power steering boot on the left hand side of my car, no serious leak, power steering fluid levels are not noticeably dropping, but my steering pulls to the left fairly bad. Is it possible to replace the boot, would it be simple. OR do you guys think that is not even the problem.
    Also, my Speedo is rooted, the circuit board has been damaged and tracks are burnt out. Is it possible to just replace circuit board with another, but take out the working brains of the old one and put them on the new fine circuit board?(Eliminating having to to to a Auto-Elec)
    commodore
    Aug 2009
    australia
    yes its easy to change the boot just remove your wheel,take a spanner 19mm i think to your tie rod end nut and loosen it to just over the top of the thread get a big hammer and hit the arm the tie rod goes through on the side to shock it loose, remove nut fully then mark the position of your tierod end loosen locknut and wind the tierod end off the steering rack shaft off you can then cut the cableties holding your ps boot on and remove boot to install is the same just reversed you will probably need a wheel alignment after but if you mark the position of the tierod end on the rack carefully it should be close enough.
    it definatley wont be the boot making your car pull to the left ,your alignments out.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    The boot won't cause the pull. The boot just protects the rack from dirt and small rocks and the like.
    Ronald Reagan (1986)
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Count the turns when removing the tie rod end, no need for an alignment afterwards, but since it pulls left, it probably needs one anyway. What are the tyres like? Have you checked the pressures lately? Try swapping the front tyres left to right and see if makes a difference.
    Visit my Facebook page
  1. Power steering rack boot replacement
    By redlion05 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2010, 08:49 AM
  2. Replacement power steering rack.
    By southy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-04-2009, 03:36 PM
  3. Vs 99 V8 power steering replacement How to?
    By kazz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2008, 09:51 PM
  4. VR Power Steering Replacement, assistance please
    By Pete284 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-12-2005, 10:24 PM
