Results 1 to 8 of 8
Thread: Rough idle, smoke, tryed lots of things.. need help!
    vp berlina(v6), vs statesman(v8)
    Dec 2008
    Default Rough idle, smoke, tryed lots of things.. need help!
    hey guys i have supercharged vt commodore and it has a rough idle, blowing some smoke and stalls if you tap the accelerator when its cold.
    Now this is what i have done.
    Replaced crank angle sensor, cam sensor, O2 sensors, spark plug leads, spark plugs, cleaned MAF sensor, cleaned air idle control valve and throttle body. Also i put a new air idle control valve on and it made the car idle at about 2000 revs so i put the old one back in.
    Anything else i should try?
    thanks for any help
    VS Stato l67
    Mar 2009
    Melb
    Its possible the LIM gaskets might need replacing. If you replace them make sure to use the metal ones that MACE and YT sell rather than the crappy standard holden ones
    Dec 2008
    sweet thanks, it it a big job? or is it better to get a mechanic to do it? also where is the lim gasket firstly lol
    Tree cutter's Avatar
    Tree cutter is offline Tree cutter
    VX Calais SuperchargedV6
    Apr 2006
    Mt Gambier SA
    LIM is short for lower inlet manifold gaskets. What colour smoke is it blowing? Black is too much fuel. White is oil.I would be checking the fuel pressure before changing LIM gaskets. It could be a fuel pressure regulator problem.
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by Tree cutter View Post
    Black = Fuel
    Grey/Blue = Oil
    White = Water/Coolant
    Hold a Rag over the exhaust, A white one, while the car is running, Then smell & feel the rag to see what it is.
    Mat
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Vu Commodore SS V8 Gen III
    May 2011
    It sounds like it needs a damn good tune, what ecu are you running?, have you installed biiger injectors and a fuel pressure reg? theres a raft of things it could be but the trial and error method for replacing items on a whim gets very expensive
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    VTII Calais International
    Jul 2011
    Melbourne, Eastern Suburbs
    Quote Originally Posted by BlackVXGTS View Post
    Have you checked if any error codes have been set ?
    +1 on that. If it doesn't give you any then try reset the ecu, drive around for an hour and check again.
  1. Car blowing lots of smoke
    By thebestsv8 in forum VE Holden Commodore (2006 - ?)
    Last Post: 19-11-2010, 11:17 PM
  2. Radiator changed & flushed, now rough idle, blowing white smoke & coolant on engine.
    By MizzVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2009, 07:10 PM
  3. Vt Series 2 Overheating Tryed a few things already.
    By ::Team420:: in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-08-2009, 05:32 PM
  4. Lots of things for sale/vic
    By iRiot in forum Parts And Other Items For Sale
    Last Post: 03-10-2008, 09:47 AM
  5. Vy Blowing Lots Of White Smoke
    By emma.henningsen in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-10-2007, 11:47 PM
Tags for this Thread
