Results 1 to 12 of 12
Thread: vt stopping after idling for a few seconds
    vt commodore
    Apr 2011
    nsw
    Unhappy vt stopping after idling for a few seconds
    hey guys... Here's a tricky one, i have a vt commodore and i replaced the battery and the fuel pump and it still has an issue. It'll start and idle for about 5 seconds max if im lucky then will completely die... Everytime i start it it will do it.... Any ideas on what it could be i really have no idea what it could be
    WHII Statesman
    Sep 2006
    Geelong, VIC
    vt commodore
    Apr 2011
    nsw
    WHII Statesman
    Sep 2006
    Geelong, VIC
    vt commodore
    Apr 2011
    nsw
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Busted key reader maybe? Very cheap and easy to fix yourself.
    Ronald Reagan (1986)
    DeiCide's Avatar
    DeiCide is offline DeiCide
    VT
    Jan 2006
    I had to replace my fuel pump about a month ago, mate put the return hose and breather the wrong way around, caused the car to randomly stall. Fixed that then was really rough idle, turned out a hose connected to the throttle body (under plenum) came undone, reconnected it and everything was back to normal. Not sure if thats your problem but pays just to check.
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Id almost say its a Fuel issue. Weather its a bad connection on the fuel pump or no fuel. Whats the reading on your gauge? If its low and you think it might normally start at that level still put $5 in and give it another shot. Sometimes the sender can shit the tin and give a false reading.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    not nescecarily a fuel issue.... but sounds like an air/fuel mix issue
    for ANY no start issue on ANY engine follow the easy method
    suck, squeeze, bang, blow. the basics an engine needs to run..
    check it has all of these parts working correctly to find the cause
    these have sections on modern engines for anyone who cares....
    signal to start ok? (immobiliser starter ecu power and earth etc)
    voltage high enough to stay cranking? (battery altenator or starter or siezed motor)
    air getting in? (blocked intake)
    air in being measured correctly?(afm or map sensor or intake leak)
    fuel? (sender failure or pump or fuel pressure reg)
    fuel pressure ok? (check at rail)
    fuel injector signals ok? (noid light check and or cas)
    injectors ok? (leaking or blocked)
    compression? (also shows if timing is out mechanically/internally)
    spark? (check coils leads plugs)
    exhaust unblocked? (blocked cat or dpf)
    exhaust air being measured? (02 sensors)
    ignition on signal maintained? (relays ecu's ignition switchs key readers etc)
    but anyways im done blabbering
    FOR YOUR CAR THIS TRANSLATES TO
    as it starts AND RUNS FOR 5 SECONDS then stalls likely immobiliser is not stalling it as it would just not start at all and just crank....and engine light flashes while cranking????? from memory~! key reader is part of the immobiliser signal circuit......
    recomend a code check for starters..........(look it up in search up there^^^^)
    note: (afm doesnt always set code if dead OR WET WITH WATER/OIL)
    i would check the fuel tank isnt empty... put ten litres in and retry... if works sender is dead or your blind
    if started AFTER you replaced pump then skip this one
    if this issue was there BEFORE you replaced the fuel pump
    then maybe air flow meter is incorrect reading to engine control module
    (as in when you said "you apply accelerator it stalls straight away" this is a cause OR fuel pressure)
    check fuel pressure would be my next check.... as maybe there is a blockage or regulator dead or pressure too high OR too low (incorrect hose connections OR incorrect fuel pump requiring adjustable fuel pressure regulator)
    (as in did replacing the pump fix the issue you replaced it for or cause this one?)
    if afm and fuel pressure and no codes is all ok
    check for a vacum leak AFTER the AIR flow METER hoses on inlet manifold etc (bit of carby spray around them all will show you IF there is a vacum leak)
    then maybe spark cutting out after a few cycles (normally just straight out die but NO START only crank)
    code with this normally--> crank angle sensor...
    I would check with a scan tool if there is an rpm signal from crank angle sensor before declaring it dead....
    next for me if all that was ok would be a compression check......
    to make sure your not chasing an internal pressure issue or timing issue (chain cam etc)
    if none of this fixes it you have missed something....... pm me if stuck still.....
    OH and i know people have there own ways of diagnosing things but generally what i have said is the basic steps i follow when i have an issue..... so if you dont like how i do things dont tell me......
    vx custom 600RR
    Oct 2010
    Quote Originally Posted by acarmody View Post
    i have to agree with the son of IT DAD KNOWS ALL check and clean the contacts around the key
    it's a common problem
    304runner's Avatar
    Mar 2011
    Central Coast NSW
    Quote Originally Posted by db_notso View Post
    You should head out to the pub mate....
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    lol left straight after that actually
  1. car takes 4-6 seconds to start
    By JoeFish in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-07-2010, 06:20 PM
  2. 0 to 200 in 6 seconds
    By madnuts in forum Jokes/Humour
    Last Post: 17-04-2010, 01:52 PM
  3. 2500 rpm for 30 seconds reset
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2009, 12:24 PM
  4. 0 To 200 In 6 Seconds
    By Dirbatua in forum Jokes/Humour
    Last Post: 10-02-2008, 02:52 PM
  5. vp 0-100 6 seconds flat WTF
    By vks in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 08:39 PM
