Results 1 to 8 of 8
Thread: How many welsh plugs??
    Did have VS Berlina now have VT Berlina
    Mar 2010
    Cockatoo Vic
    Default How many welsh plugs??
    Hey everyone while im rebuilding the VX v6 engine i thought i might change the welsh plugs as well the person at Bursons told me there was only 2 different sizes and that there was 10 of them can any one confirm this????
    Because when i went to take the old ones out today i can only find 9/10 and there seems to be 3 different sizes am i missing something for does the person at Bursons not telling the truth.. ???
    vs commodore
    Oct 2009
    Tamworth NSW
    Im pretty sure theres 2 in the heads,one at each end,and theres 2 at each side of the block and 2 at the rear of the block.That makes 10.
    EDIT.Just looking at the workshop manual for the ecotec V6,and at the older buick V6,and the buick looks like it has 3 rear welch plugs behind the gearbox/transmission, but the ecotec doesnt look like it has these,it just has the rear alloy plate that also contains the rear main oil seal. .The larger middle welch plug at the rear on the buick is probably not for the cooling system,im not 100% sure on this though,Im only going off what I can see in the manual.
    Mar 2010
    Cockatoo Vic
    The ones i have found are the 2 big ones on each side of the block and 1 small one at each end of the heads and i can only find one really small one at the back of the block :S
    scvs6's Avatar
    scvs6 is online now Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    I just went out and counted them on my s/charged v6 block (which should be about the same) and I only counted 9 as well.
    1 on the front of the left head.
    1 on the front of the right head.
    1 on the back of the left head.
    1 on the back of the right head.
    1 on the back of the block right next to the left head.
    2 on the left of the block.
    2 on the right of the block.
    Unless there is one behind the plate where the rear main seal is. I haven't removed mine yet.
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    vs commodore
    Oct 2009
    Tamworth NSW
    Id go back and tell the guy at bursons to check if theres a difference between the buick V6 and the ecotec welch plug locations and numbers.Looking at the workshop manual, it looks like the buick does have 10 of them,but the ecotec doesnt have the rear ones where the alloy plate is.Id say the guy at bursons is thinking the ecotec is the same as the the buick engine.
    Mar 2010
    Cockatoo Vic
    Mar 2010
    Cockatoo Vic
    Quote Originally Posted by Brett_jjj View Post
    I say you are right i will be getting them from R&E AUTO prom Pakenham Vic as the were cheaper there anyway thanks for your help guys.
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Quote Originally Posted by superchargedvs6 View Post
    Yes this is correct for an ecotec block. There is actually 2 more, but there's generally no need to touch them as they dont block coolant passages. This is the 2 that block the main oil galleries at the front of the block behind the front timing cover. They're approx 15mm dia.
    There is none in behind the alloy plate at the rear. The gasket used with this plate is what blocks the rear coolant passages.
  1. how to change welsh plugs??
    By justin.995 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2010, 12:01 AM
  2. VR V6 Welsh Plugs
    By HÝPÕ-5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2010, 10:25 PM
  3. welsh plugs
    By vn nut in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2008, 12:14 PM
  4. welsh plugs
    By Wonderboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2005, 12:33 AM
