Results 1 to 17 of 17
Like Tree1Likes
  • 1 Post By GEN3RATD
Thread: VT Hollandia sunroof not working
    Holden vt calais 5 litre
    Nov 2007
    Default VT Hollandia sunroof not working
    Hi I just brought a new 97 calais with a hollandia sunroof and the sunroof will not respond to any input from the controls no clicking sounds also how do i troubleshoot this? what fuses should I be looking for?
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    I'd be removing the fuse panel under the steering column. Somewhere here you should find 2 additional remote fuses in a holder. These are inline of the constant and ignition power source from the harness feeding to the ignition barrel and up the drivers 'A' pillar to the sunroof control switch. Also look for an additional relay connected to the sunroof wiring that may be faulty. The hollandia units fitted in 97' often didn't use an additional external relay so don't be alarmed if you cant find one.
    Hope that gives you a start.
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    Nov 2007
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Nov 2007
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    try puttin 12V directly 2 the motor n see if u can hear it trying 2 move. if nothing the motor could b stuffed/seized.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
    Aug 2008
    NSW South Coast
    Have you tested with a multimeter/testlight that you actually have 12v upto the unit itself?
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    seriously, if you drop in they can fix it straight away. even call them and ask.
    If it isnt tuckin, it must be suckin
    Nov 2007
    Quote Originally Posted by cander24 View Post
    i pulled the switch out and probed the connector with a testlight, it looks like the sunroof isnt getting power
    Aug 2008
    NSW South Coast
    Quote Originally Posted by justice4all3000 View Post
    So, assuming this is correct, the problem may lie somewhere between the switch and the power source. You mentioned you checked all the fuses, however, were these the fuses in the standard fuse panel? Or did you located the two extra's for the sunroof?
    Nov 2007
    all fuses have been double checked, there is no fuse labled sunroof though
    Aug 2008
    NSW South Coast
    You wont find one labelled 'Sunroof' in the fuse panel. The two fuses you're looking for will be in a remote/inline fuse holder in the actual electrical wire itself. Locate the main wiring harness that feeds up the steering column. Branching off this harness should be 2 wires (likely both red) and this will go across to the drivers side in this area and eventually up the front A pillar. These are the constant and ignition power sources for the sunroof. Each of them will be fused. The inline fuse holder will often be blue and they often use the 3M scotchlock type. See pic below.
    Attached Thumbnails Attached Thumbnails VT Hollandia sunroof not working-imagesca6vizx7.jpg
    Z' Series HSV 297KW 6lt LS2 Conversion For Sale!
    PM Me For Details
    Nov 2007
    just had a look couldnt find anything like that
  15. #15
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Not too much experience in this but I'm going to contribute an idea.
    Although the fuses may be fine, I'm assuming that the sunroof motors actually utilise a relay?
    If this is the case, a screwed relay would account for the issue.
    Good luck.
  16. #16
    Aug 2008
    NSW South Coast
    Im not trying to sound smart about it, but keep looking. They’ll be there. Maybe then remove your drivers A pillar plastic trim to reveal where the power wires to the sunroof run and then track them backwards to the source.
    As I mentioned in an earlier post and also by Jesterarts above, also look for an additional relay that has been fitted somewhere here in the steering column/fuse panel area. As I mentioned though, I wouldn’t be surprised if a 97’ model unit didn’t utilise one.
    Essentially, you need to find exactly where it is picking up power from. Between this location and the sunroof switch it will be fused. Have you removed the steering column plastic surround to inspect the harness? This is where most sunroof installers will splice into. In this main harness it will be a red and a brown wire.
    PM Me For Details
  17. #17
    Nov 2007
    can someone please post a pic of this mystery fuse location, would be greatly appreciated
  1. [VIC] WTB: VR/VS Sunroof
    By nathanVY in forum Swap / Wanted to Buy / Trade
    Last Post: 27-12-2010, 02:53 PM
  2. Ute Sunroof?
    By J@m3$ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 09-06-2010, 04:20 PM
  3. VT factory Hollandia sunroof
    By Amy aka boozey in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-05-2010, 02:54 PM
  4. traction control light on dash not working... except for the fact that it is working
    By redcv6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-07-2009, 10:41 AM
  5. Hollandia sunroof
    By radiohead in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-03-2009, 01:15 PM
