Results 1 to 25 of 25
Like Tree1Likes
  • 1 Post By BlackVXGTS
Thread: battery light on when headlights turned on
    Holden vt calais 5 litre
    Nov 2007
    Default battery light on when headlights turned on
    my battery light comes on when headlights are turned on what should i do??
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Get your battery and alternator checked by an auto electrician.
    MY RIDE
    VY SS
    May 2011
    Auckland
    With the car idling check the voltage across your bat. Should be at least 13v
    Nov 2007
    with the engine running and accesories running (headlights, AC, stereo ect) the batt is at about 14 volts however when i turn the rear demister on also it drops to about 12.3 volts is that ok?
    Commodore M6
    Jul 2010
    East Coast
    i would say no
    should be 13.8 no matter what is going on
    short? leak? in the rear demister circuit?
    Nov 2007
    Quote Originally Posted by TonyJZX View Post
    i would say no
    How do I test the rear demister for problems?
    Thanks
    VY SS
    May 2011
    Auckland
    Unplug it off the window. Probably under the pillar cover. Pull the fuse. Test for continuity on the car side of the connector not the window side (you shouldn't have it)
    Nov 2007
    Quote Originally Posted by m1lky View Post
    thanx will give it a try
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Replace your voltage regulator. Easy and cheap fix. The bushes in the regulator wear down over time and result in the alternator not being able to keep up its normal charge rate. Vary your test by leaving the headlights off and the rear demister on and see if the battery light comes on. If it doesn't then turn the headlights (I assume you had high beam on) to see if the battery light comes on. That should establish if the problem is the rear demister or the regulator (or some other part of the alternator).
    Nov 2007
    yesterday the battery light came on again, this time the rear demister was not on so i doubt its the cause of the problem. Where can i get a voltage regulator from? do i have to remove the alternator to replace it? (series 1 v8)
    VY SS
    May 2011
    Auckland
    Test your alternator and reg first. With high beam on for a decent load.
    You can do it yourself as above or chat to autosparkie. He'll prob do it for free.
    Alternators wear out at the end of the day. Shouldn't be too hard to replace if it has. I'd get yours reconned or a new one rather than second hand
    Nov 2007
    just tested it with a multimeter with the engine running again its putting out 14.5 volts and when i turn on all of the accessories on it drops to 12.4 volts however if i keep the enging revving a tiny bit the voltage will return to 14.5 volts does this definitely mean that the alternator is to blame I just dont want to waste my time and money replacing it if its somthing else!
    thank you to everyone who has been helping me with this
    VY SS
    May 2011
    Auckland
    Seems like it's not keeping up to me.
    Are your battery terminals tight and clean?
    I'd replace alternator (would assume regulator is inbuilt). If your worried take your car to an auto sparkie first they can test it
    Nov 2007
    I recently put in a one year old battery out of a vn v6 could that have anything to do with the problem?
  15. #15
    wrx884's Avatar
    wrx884 is offline WA's ASR Rep
    VT Commodore Exec/5L VP Calais
    Mar 2006
    its ur regulator on its way out, not the alternator.
    with the car off wat does ur battery read? if its around 12.5V then its fine and not that either.
    Check out my ride in progress.... 98 VT V6, V8 Supercar kitted
    Daily toy.... 92 VP Calais 5L
  16. #16
    Nov 2007
    thinking about replacing the alternator with a secondhand one (tested with warrenty) is that a good idea or should i go brand new?
  17. #17
    wrx884's Avatar
    Mar 2006
    regulator $15, u can go through 2-3 of them b4 needing a new alternator ud b best 2 do that 1st.
  18. #18
    Nov 2007
    Quote Originally Posted by wrx884 View Post
    where can i get one from? bursons?
  19. #19
    wrx884's Avatar
    Mar 2006
    Any auto store that sells parts should have them as they r fairly common. (not sure wat bursons is dont think we have 1 of those in perth lol).
  20. #20
    Nov 2007
  21. #21
    Nov 2007
    ok replaced the voltage regulator with a brand new one the voltage its at a steady 14.3 volts however if i turn absalutly accessory on the voltage hangs around 12.5 to 13 the battery light hasnt come on yet
  22. #22
    wrx884's Avatar
    Mar 2006
    check all ur grounds now and if u got a sound system in the car have u done the Big 3 upgrade? even if u havent its not a bad idea 2 do it and it helps alot specially if u use alot of accessories. its just upgrading all ur grounding wires in the bay.
    if it still fails get the new regulator checked out and make sure its working fine ive had brand new genuine regulators fail on me b4.
  23. #23
    Nov 2007
  24. #24
    wrx884's Avatar
    Mar 2006
  25. #25
    Nov 2007
    took the car to an auto elec today got everything tested it seems that replacing the voltage regulator fixed the problem and i was told that its normal for the voltage to drop to around 12 while idling with the accessories on. I will probly do the "big three upgrade" when i get round to putting a sub and amp in
  1. Engine Light Comes On When Key Turned To ACC
    By freddyfinn in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-12-2009, 03:57 PM
  2. VT II Brake Light Comes on when Headlights are turned on.
    By chrisrigney in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2007, 05:19 PM
  3. VT II Brake Light Comes on when Headlights are turned on.
    By chrisrigney in forum Electrical Wiring / Questions
    Last Post: 30-11-2007, 10:53 PM
  4. All Interior Lights stop Working When Headlights turned on
    By GMTANK in forum Electrical Wiring / Questions
    Last Post: 30-08-2007, 11:24 AM
  5. VXII Acclaim Cruise drops out when headlights turned on
    By nevd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2006, 01:09 PM
