Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By Not_An_Abba_Fan
Thread: Camber Kit for VX S2 Spack.
    VX S2 S Pack
    Dec 2009
    Default Camber Kit for VX S2 Spack.
    My tyres are rubbing out on the inside rear tyres and i got told i need a camber kit, but i keep reading that Series 2 have a camber kit, whats the go? also i got told there are 2 different types of camber kits in the rear end?
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    series two as fair as im aware do NOT have a camber kit, rather an extra link. it helps with the rear end camber but doesnt solve it. for example my VXII SS was on ultra lows, and you couldnt see any camber at all, when i had a wheel alignment done on it it had less then a degree of negative camber. whereas others have complained of excessive rear end camber.
    a VXII only needs a 2 point camber kit as opposed to a 4 point.
    If it isnt tuckin, it must be suckin
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The series 2 has adjustment, but it's only really toe. You can get two different kits, a 2 point or a 4 point. For best results fit a 4 point, it gives you a lot more adjustment. I can do you a 4 point SuperPro kit for $175 posted.
    Visit my Facebook page
    jayperformance is offline light it up
    vn Calais 5l
    Jul 2011
    griffith
    VX S2 S Pack
    Dec 2009
    I'M in Adelaide, any recommendations on what place would be the cheapest, and how much would i be looking at for 2 point fitted or 4 point fitted approx?
    VXSS
    May 2007
    dont get a camber kit, I been told to get most of the gear out of the ass of a vy as they are camber corrected and it should all fit in.... but it wont help your case if you are gonna do anything than run it any less than standard ride height.
    VX S2 S Pack
    Dec 2009
    VX S2 S Pack
    Dec 2009
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The VX2 and the VY have the same rear end.
    vn Calais 5l
    Jul 2011
    griffith
    it will cost anywhere between $450 to $650 depending on how compentant the mechanic is
    180sx
    Nov 2009
    It would be a big waste of time and money to swap a VX2 rear end with a VY rear end as they are the same.
  1. vs spack
    By chocbox in forum VR - VS
    Last Post: 24-09-2011, 07:59 PM
  2. Camber Kits and Camber Adjustment
    By impulsive in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 22-12-2010, 10:07 AM
  3. VT Rear Camber Issues = FE2 Springs Require Camber Kit?
    By Puma in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2010, 05:46 PM
  4. VS Spack and LSD
    By damien1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2010, 07:33 PM
  5. vx spack no lsd
    By deno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-10-2007, 09:47 PM
