Results 1 to 14 of 14
Like Tree6Likes
  • 1 Post By FATMOE
  • 1 Post By acarmody
  • 1 Post By nathanVY
  • 3 Post By some_guy
Thread: Burnout and engine light help
    vt commodore
    Dec 2010
    sunbury
    Default Burnout and engine light help
    Hey guys and some family problems tonite so I reversed out the driveway in anger slapped my vt v6 exec into first got the wheels spinning up pretty good but then it felt like the car was stuck in gear and the engine light was on so turned it off then on and it was gone and car was driving normal....shoulf I be worried? Is it common? Please no smartass comments
    VY Clubsport R8
    Sep 2010
    I wouldn't be worried, I was once sitting my ss and suddenly my overspeed light appeared. WTF
    Hangman's Avatar
    Hangman is online now Torana Addict
    2 commys, 3 Toranas and a WB Panel Van
    Jan 2010
    Newcastle, home of Toranafest
    Check your fault codes. Engine light generally means a code was logged.
    Mzak89, do you mean the speed alert? If so, how fast were the wheels turning and what was it set at?
    Quote Originally Posted by hakhawk View Post
    there are more pressing issues on the site, like choosing between vl's and potatos.
    VY Clubsport R8
    Sep 2010
    Yeh the speed alert the wheels were spinning quickly my front windscreen was covered with smoke within 10 seconds my limit is set at 110
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Quote Originally Posted by mzak89 View Post
    2nd or 3rd gear? Can't be first because you can't spin that high in first, unless it wasn't the speed alert light.
    Ronald Reagan (1986)
    VX acclaim S2
    Oct 2009
    Powertrain light, ur trans was overloaded temporarily, logging a stored fault for powertrain
    vt commodore
    Dec 2010
    sunbury
    VX Berlina
    Apr 2007
    Shouldn't be, likely it was just the car trying to stop it destroying itself. Torque and rev limiters.
    VK -Project-, VX R8 Clubsport
    Feb 2010
    Tamworth NSW
    hehehehe generally happens when a neutral snap skids done in an auto, i had one and it did the same thing, 1st time is nothing to worry about but try not to do it again or after a while the auto will make some very strange noises hahaha
    VX acclaim S2
    Oct 2009
    Haha that's right I did it once, got the respect from my mates cox they have never seen a neutral bomb dropped like that haha but the power train said no no haha once n my lesson is learnt
    Feb 2010
    Tamworth NSW
    Quote Originally Posted by kizza50 View Post
    seems like a fair reason :P isn't that the only reason we do skids ? hahaha
    my mate copied me, he had a VN and was always trying to figure how to do skids .... he went a lil crazy and blew the arse outta his auto hahaha was very ####ing funny
    nathanVY's Avatar
    nathanVY is online now need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    This made me laugh.
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
    VX acclaim S2
    Oct 2009
    Gotta try everything once right
LinkBacks (?)
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. Vt 5.0 idle problems and missing also engine light and oil light come on
    By vtss5.0 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2011, 07:32 PM
  3. HELP Engine Light / Transmission light and rough gear changes
    By flash20005 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2010, 03:34 PM
  4. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
