Results 1 to 13 of 13
Thread: Why does the engine go 'tack-tack-tack' when the air conditioning is ON?
    VX Executive
    Feb 2008
    Default Why does the engine go 'tack-tack-tack' when the air conditioning is ON?
    this happened on the way home on a freeway. I thought it was the transmission but the car changed gears smoothly. the sound would accompany the revs in the engine but would totally disappear when the air conditioning is switched off. whats happening?
    Holden vt calais 5 litre
    Nov 2007
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sounds as though the AC compressor clutch is on the way out.
    Visit my Facebook page
    VX Executive
    Feb 2008
    AC compressor clutch? Can this unit be replaced separately? or do i have to shop around for a new compressor? Its mighty expensive...
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by blacknight View Post
    The clutch can be replaced separately.
    MY RIDE
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It's probably the tensioner making the actual noise, this would be because the clutch on the compessor is tight putting too much tension on the belt. Either that or the comprressor itself is stuffed. Remove the belt and spin the AC pulley to see if it is noisy, then turn the AC on and then see if it can still spin relatively easy. It will be tighter, but it will be tight/loose/tight/loose, if it is just tight all the time, it may be shot.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Quote Originally Posted by accentstencil View Post
    Really? Sweet. My AC clutch is shorted, so everytime I turn it on it blows the fuse (which also powers the MAF I think, who thought that was a good idea?), so currently it is disconnected. Where do you get the clutches from? Holden?
    Ronald Reagan (1986)
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    Quote Originally Posted by acarmody View Post
    Holden should have them, I priced one many years ago and I think it was around $300, not cheap.
    MY RIDE
    Nov 2007
    VX Berlina
    Apr 2007
    Bloody hell, I think I would rather replace the whole unit for not much more, at least than you know the compressor won't shit itself in a few months.
    vx s pack II
    Jan 2010
    aLKIDA
    When you regass the system there should be oil added in the air-conditioning system this will go through the system as a lubrication for the parts.
    Could be the compressor internals or clutch as stated above.
    showbags's Avatar
    showbags is offline Cheap,nasty&full o shit
    VT Calais,F6E
    Dec 2009
    Had a similar noise in my VT, replaced the belt and the noise disappeared. I could swear I had a rooted idler pulley.( knew it wasn't air cond compressor-I replaced that 6 months ago).
    VX Spac
    Jun 2009
    same thing happened to my commy, and yes it's the compressor clutch.
  1. Vy Air Conditioning
    By Jono VY2 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-11-2009, 08:23 PM
  2. Pioneet Head Unit and Aerial - Different tack needed
    By Achtungbabi* in forum Car Audio
    Last Post: 23-06-2009, 11:15 PM
  3. VR air conditioning
    By SLR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-12-2007, 07:26 PM
  4. Air Conditioning
    By Holden4fun in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2007, 02:02 PM
  5. air conditioning
    By clinker42 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-09-2006, 05:34 PM
