Results 1 to 5 of 5
Thread: Door locked and won't open
    VT SS 5.7
    Sep 2009
    Kuwait
    Exclamation Door locked and won't open
    I need some creativity here one of the rear doors is jammed, the door lock button as well stuck, i tried to lift it so I'd be able to open the door, I did manage to open the door but did not have time to figure out how to solve this, I remove the inner door cover, and hopefully be able to open it again to solve this.
    If you have any idea on how to solve this or know the reason why this is happening it would be pretty helpful.
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    Sounds like you need to adjust the door catch on the body of the car. Loosen the 2 Torx screws and adjust it up or down.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    See if it works with the door open. Use a screw driver to lock the catch while it is open, then see if you can move the door lock button. If not, the actuator may be seized (never seen this happen though) or it may be a linkage damaged or seized. If the door does unlock, then it may be adjustment. Slowly close the door and see if it moves up when it meets the catch on the body.
    Visit my Facebook page
    VT SS 5.7
    Sep 2009
    Kuwait
    I'll check the catch first, thanks for the help.
    I'll let you know about it when I fix it. VTs are nice but never make them angry
    cheers
    vn commodore
    Jan 2011
    adelaide
    hi i have a vn wagon tailgate stuck taken the lock out but still stuck any ideas thanks
  1. How to open dead locked rear door VT Calais
    By sxc_sound in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-06-2011, 01:33 PM
  2. VT door latch locked cant open!
    By Ben. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2011, 10:45 AM
  3. Boot Wont Open. Aberrantly valet Locked.
    By anonymousmoose in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-10-2010, 08:08 PM
  4. Door locked wont open???
    By reddog in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-07-2008, 07:49 PM
  5. how to open a locked cabinet?
    By Torquative in forum The Pub
    Last Post: 19-03-2008, 01:30 PM
Tags for this Thread
