Results 1 to 6 of 6
Thread: VX II Berlina keyless entry
    Holden VX II Berlina
    Jun 2011
    Inverloch
    Default VX II Berlina keyless entry
    Hi,
    Today when i went to unlock car i used keyless unlock, and when i went to open driver door it was still locked. When i used the actual turn to try and unlock it the inside door opener popped up just a little bit more and i was able to open the door.
    Its just the drivers door that does this, and just wondering why the whole insider door opener isnt popping all the way up, i have to manually open the door instead.
    Any ideas?
    Cheers in advance
    VX SS
    Jul 2011
    Could be the door lock actuator, they are known for only opening a little bit when they start to fail
    Jun 2011
    Inverloch
    VX Calais LS1, VS Calais L36
    Mar 2010
    Are you asking if the key need to be replaced if you replace the actuator? No. The lock on the door is a separate part joined by a rod.
    Mine was doing the same thing. Pulling out the actuator and lubricating it seems to have done the job.
    VX SS
    Jul 2011
    yep, my VZ did that, first the drivers door then the passengers, holdens just replaced all actuators and it worked fine ever since, you can get the actuators off ebay for cheap...well cheaper then holdens
    Jun 2011
    Inverloch
    cheers guys
  1. [Help Needed] Holden VN Berlina Wagon (Want to buy keyless entry!)
    By Excale in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-06-2009, 04:18 PM
  2. keyless entry
    By mason_luke in forum Electrical Wiring / Questions
    Last Post: 05-11-2007, 11:58 AM
  3. Keyless Entry?
    By Keesh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-11-2006, 11:41 PM
  4. Keyless Entry
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2006, 03:01 AM
  5. Keyless Entry
    By micheledip in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-01-2004, 02:41 AM
