Results 1 to 13 of 13
Thread: IGNITION LEADS QUESTION?????? attached image
    vx commdoore
    Nov 2010
    sydney
    Default IGNITION LEADS QUESTION?????? attached image
    guys i wanna install new ignition leads on my car , here i attached a copy from a GM service manual on how to but there is something i don't understand about it is when they say(When reinstalling plug leads, route leads correctly and through the proper retainers. Failure to route the leads correctly can result in the lead/s chaffing, burning, or causing cross firing of the plugs or shorting of the leads to ground.)
    what do they mean by route leads correctly through proper retainers...
    thanks in advance.....
    Attached Thumbnails Attached Thumbnails IGNITION LEADS QUESTION?????? attached image-untitled.jpg
    vz wagon
    Aug 2006
    Wild west of Melb
    put the in the corect little plastic clip that holds them in place so the dont cross over another lead there is a picture of the clip in the top pic that you put up. well thats my understanding.
    vx commdoore
    Nov 2010
    sydney
    vx commdoore
    Nov 2010
    sydney
    OK but what bout the 3 leads that goes under the alternator, they all are in a plastic tube nothing is separating them at all...
    you know what am saying mate,,,,,,,if the service manual saying that you must route leads correctly and through the proper retainers in-order to avoid chaffing, burning, or causing cross firing of the plugs.... so what bout the 6-4-2 plugs that goes under the alternator and nothing is separating them....
    WogBoyz's Avatar
    WogBoyz is online now Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by casper0 View Post
    On my old ecotec v6 i had the 10mm leads and they crossed over and what not, never had any problems
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Quote Originally Posted by WogBoyz View Post
    Same.
    I don't even have that bendy-pipe stuff over the 2-4-6 leads, not needed. Nor are any of those clip holding the leads on my car, my 9mm leads don't fit in them.
    Ronald Reagan (1986)
    vx commdoore
    Nov 2010
    sydney
    CV8 Monaro & VE SV6
    Sep 2009
    All its saying is make sure the timing order is right, ie correct lead on the correct plug and keep the lead away (as much as possible) from direct heat sources.
    The biggest issue with leads is that the silicone core will break over time and when it does, the spark strength becomes less as it has to jump the break in the core.
    Hope that all makes sense. I wouldn't worry about it too much, just make sure you put them back where they were originally.
    vx commdoore
    Nov 2010
    sydney
    mate i think the whole assembly of the entire ignition system is totally disgusting and wrong..... it is too close to the manifold exhaust.....
    Quote Originally Posted by Aussiecv8 View Post
    vx
    Aug 2009
    your absolutely right mate, Holden admitted that there was an issue with the firing order it was totally wrong and with the ignition system as-well.the engine was suffering from a permanent vibration at the beginning...... really the v6 ecotec is a flawless creations BUT what did actually kills these engines is the crappy head gasket and the way the leads plugs in...
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by acarmody View Post
    Same.
    Yeah i didnt have any of that either and over the 2/3 yrs i had them on i didnt have any trouble
    Killr6's Avatar
    Killr6 is online now on boost
    XR6T
    Sep 2010
    Hervey Bay QLD
    i never put the black stuff back over the leads, i just left them and they worked fine. never had a problem
    Starin at the world through my rearview
    Go on baby scream to God, he can't hear you
    I can feel your heart beatin fast cause it's time to die
    Gettin high, watchin time fly
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Remove alternator and you can easily remove and install the leads through the black conduit. It is a good idea to keep them within this conduit as they will rub on the engine and could stuff the leads' insulation.
    As for running them together and having potential spark jump- bullshit, unless the insulation was stuffed which it won't be if they are new leads and are run within the conduit.
  1. [LS1] Ignition leads.
    By soop in forum LSx Development and Modification
    Last Post: 26-05-2012, 06:12 PM
  2. What IGNITION LEADS Leads do you use?????????
    By 11gothevt11 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2010, 09:03 PM
  3. A question regarding ignition leads
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-02-2007, 10:05 PM
  4. Simple ignition Leads Question
    By squidda in forum Electrical Wiring / Questions
    Last Post: 19-07-2006, 11:34 AM
  5. A question about Ignition Leads
    By fazz1977 in forum Electrical Wiring / Questions
    Last Post: 22-11-2005, 04:05 PM
