Results 1 to 6 of 6
Thread: Tyre pressure
    VT S-Pack S2
    Sep 2010
    Default Tyre pressure
    Hey everyone,
    Iv got 18x8 rims with 235/40/18 just wondering what the ideal tyre pressure would be? Not sure if this helps but i do alot of hills (as in hard corners etc.)
    any help would be great cheers
    VX acclaim S2
    Oct 2009
    Vp berlina s2
    Jul 2011
    Harvey bay
    I run 235 40 18" and it all depend on the road surface, smooth highway style roads, I put them at 40 psi, but rough outer suburb roads, bout 35... Depends really on you and wat sorta ride you want....
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Quote Originally Posted by sus_038 View Post
    Hey everyone,
    No one can answer that question properly as every tire takes a different psi in it, it just depends on how good the tire is and what you like! You also haven't provided what tire you've got, you posted up the size of the tire which could be any one of the 10000 tires out there that are made in that size.
    Best way to answer your question is: check on the side of your tire look to see what the suitable min-max pressures can be and pump the tires up to around three quarters max pressure and go from there.
    VT V6 fitted with DMS gold 40mm coilovers, Whiteline adjustable swaybars & strut brace, 330mm AP racing brakes, Rebuilt 3.45:1 LSD and a Powerdyne supercharger
    Check it out: http://forums.justcommodores.com.au/...-v6-racer.html
    VT S-Pack S2
    Sep 2010
    VT Calais
    Mar 2009
    SA - Victor Harbor
    i used to work at a tire shop, the general rule of thumb is whatever your rim size is, double it and +2 so for you a tire shop would recommend 18x2 = 36 +2 = 38PSI
  1. tyre pressure
    By gungazza in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-05-2010, 09:52 AM
  2. Tyre Pressure
    By dephilile in forum General
    Last Post: 14-04-2008, 02:07 AM
  3. Tyre Pressure
    By syth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2008, 02:36 PM
  4. Tyre Pressure!!?
    By AlX in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-05-2006, 11:32 AM
