Results 1 to 13 of 13
Thread: WH Statesman Overheating Issues
    WH Statesman V6
    Jul 2011
    Banksia Park
    Default WH Statesman Overheating Issues
    Took my 01 Statesman in for its 200K Major Service a few weeks back. Noticed a few problems with it overheating, Replaced Raditor, Hoses, Water Pump, Complete Flush and Pressure Test.
    After all of that the problem still is happening. Holden at hope Valley can't find any errors with it at all, they said it might be the oil so they changed it.
    A new problem has now started im filling up the radiator every two days now, there are no leaks and the pressure is fine. Once i fill it up there is a foamy camel colour that appears.
    The car has been back to Holden six times and the problem still is happening.
    Two days ago notice Creaming Paste on the oil Cap, i've not driven it yet not sure what the hell is wrong with it.
    Can anyone help.
    vs commodore
    Oct 2009
    Tamworth NSW
    Id say the inlet manifold gaskets are leaking/blown.A very common problem with these engines.At least they are cheap and easy to replace.They should have showed up in the cooling system pressure test though..
    WH Statesman V6
    Jul 2011
    Banksia Park
    Well thats the thing Holden Couldn't find any problems with the car just sent me on my way, got 10mins down the road and sure enough overheated. All i can say thank god for the VS i didnt sell or i would be stuffed
    WH Statesman V6
    Jul 2011
    Banksia Park
    Commodore M6
    Jul 2010
    East Coast
    WH Statesman V6
    Jul 2011
    Banksia Park
    Thats what im wanting to know, when they told me it was the oil they made me wait around for 5 hours until it was done. After i was told it would only take 1 hour at the most.
    vs commodore
    Oct 2009
    Tamworth NSW
    You can buy the metal type inlet manifold gaskets from mace engineering for $110,see the first link below.These apparently wont fail like the standard plastic type gaskets do.I havent tried them yet myself,but when mine are due for replacement again,I will be giving them a go.As for the standard plastic gaskets ,I couldnt find any to get an idea of their price,but I found a VRS gasket set,which includes the new inlet manifold gaskets you need,they are not exactly cheap though at $150.See the bottom link.Someone here might be able to point you to some single inlet manifold gaskets that are cheap.. If you are gonna pay someone to do the job,then Id still get the metal type gaskets and just get them to fit them for you.The cost of getting it done by a mechanics depends on where you take the car,so I cant really give you an amount,maybe around the $300 to $500 mark? Ive no idea really as I do all my own work.You will have to shop around and get a few quotes.Let us know how you go.
    ---Inlet Manifold Gaskets - Mace Engineering Group---
    ---COMMODORE VT VX VY .. V6 VRS GASKET SET ..NEW .. | eBay---
    Vp berlina s2
    Jul 2011
    Harvey bay
    Default also watch auto's
    I have had auto lines in the radiator let go, and water end up in ya trans... So bypass radiator trans cooler and just run an aftermarket front mount 1.... Just a heads up!!!
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    WH Statesman V6
    Jul 2011
    Banksia Park
    Yeah they did a compression test all was normal, i'm taking the car down to be looked at i need it fixed.
    WH Statesman V6
    Jul 2011
    Banksia Park
    Well one problem found so far, Inlet Manifold is leaking. But may also have a problem with exhaust leaking to. Mechanic said car would be fine to drive until he can repair it next week some time.
    Just wanted to know if the car is safe to drive. Don't want to blow my motor.
    wh statesman 5.7
    Dec 2011
    adelaide
    mine is doin the same its fried two thermostats everywhere ive taken it they say its the thermostat i thought it may have been a airlock i work away first chance ive had to look at it and now the trans is slipping in every gear even reverse this car hasnt had a hard life?
    ucwepn's Avatar
    ucwepn is offline America just kicked in yo
    WH statesman 5.7
    May 2005
    krm88 it sounds bad mate, sounds like the overheating and the trans slipping could be contamination of trans fluid with coolant and vice versa (inside the radiator theres a transcooler and it may be damaged), get it checked asap and don't drive it.
    ========My Statesman 20's Mafless and 3.9's========
  1. Overheating issues...
    By L-VrCalais in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-11-2010, 12:35 PM
  2. Vq statesman 5 litre overheating
    By LOWPSI in forum V8 Development and Modification
    Last Post: 19-10-2010, 09:02 PM
  3. VQ STATESMAN 5.0 issues
    By GMBanisher in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2010, 03:14 AM
  4. Overheating statesman
    By ruler71 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2007, 10:14 PM
