Results 1 to 15 of 15
Thread: $100 for someone who can guide me through replacing airbag + sensors
    VX Executive
    Jul 2011
    Default $100 for someone who can guide me through replacing airbag + sensors
    Hi everybody,
    Firstly, I don't know F all about cars and was hoping someone could help me. I was in an accident and the airbag was deployed. I've paid $2000 so far for getting all the main stuff fixed (panel beating, new door, back axel fixed), all that is left is the airbag and all its sensors. I have gotten 2 quotes of around $800...which I don't have. Not to mention it needs a service, roadworthy and new rego.
    I was told two things:
    1: All sensors and airbag needs to be replaced (Holden)
    2: It is impossible that the airbag went off because they only deploy when your in a head on (I hit a pole at about 30k/m near the back/left wheel), and a quick change of the airbag will do (Smash repairs mechanic)
    I need someone to tell me the following...
    *What or IF sensors need to be replaced
    *Where to get parts
    *Details on HOW to replace
    *Any information I need to get the airbag system working again
    *Also, because I don't know shit about cars, the information needs to be verified by others.
    $50 to start, and $50 when it's finished via paypal/bank deposit. Easy money if you know exactly what to do
    I don't know much about cars, but I know a little about electronics and believe I could do it myself with the right guidance. The car is a 2001 VX executive, any help would be much appreciated. Thank you
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    i would assume it has 2 airbags, one on the steering and the other under the passager side dash? if so
    Disconnect the battery first!
    steering wheel airbag is held on by 4 torq screws on the back of the wheel, easy to remove,
    under the dash, is a prick if its anything like the VS, the dash has to be removed.
    if it only has the 1, its on the wheel.
    **DISCLAIMER**
    Advice is given freely, which may or may not be correct, do what you will with my adivce/opinion without liability to me. preceed at your own risk
    Now since none of the airbag system was touched nor deployed, you shouldnt have to replace any part of it. HOLDEN will tell you to replace it all to cover there ass; if for some reason it doesnt deploy if you have a head on colision from here on in. its there duty to advise you on the safest route!
    how much do you value your life, do you risk doing nothing or doing it all for your own piece of mind..
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    As someone who has had these things replaced. seriously get an auto-elec to do it. buy all the gear you need. get the airbags from a wreckers, get the sensor from holden. and also get the pretensions from holden, both new. grab a second hand dash pad. walk into a auto-elec and it shouldn't cost more than $400 for them to do the job.
    Also does the car need a VIV ?.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Correct me if I'm wrong doesn't it need to be done properly cause it's a safety device. In fact isn't it now technically classed as repairable write off?
    calais24/7's Avatar
    calais24/7 is offline Mucca Mad Boys
    VS Calais II 5L, 98 rodeo v6
    Jul 2009
    I know f all about airbags, htis is why im asking. If it hasn't gone off what is the point of getting them replaced? And won't it only be classed as a repairable right off if he goes through insurance?
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    calais24/7's Avatar
    Jul 2009
    haha fk im silly, i just went to re read it and it said it in the first sentance. You should probably leave the airbags to a professional mate
    VX Executive
    Jul 2011
    Thanks heaps for the replies, so everyone agrees it should be left to the pro's? Full spectrum, do you know an exact part list I would need? and whats a VIV?
    I have a new airbag already, its the sensors im worried about, and all these electrical modules that ive been told to replace.
    Also, would one of those scan tools (tech2?) that the mechanics use, would that tell them exactly what was wrong?
    VX SS
    Jul 2011
    argee, its potentially your life that may be at risk if you do it yourself and you crash and the bags dont deploy
    stuntmanmike's Avatar
    stuntmanmike is offline Car wotsit & stuff
    VP 3.8 V6 Auto and VS BT1 5.0
    Jun 2009
    At home on planet earth...
    Worst still, is handling the air bag inflator unit that is sensitive to static electricity. Sitting in the seat of your car with woolens or polyester clothing could generate static electricity and ZAP when you earth on something conductive (eg fingers touch something grounded to the car body). If this happens while handling the air bag inflator and it detonates then it won't be a nice result. It is an explosion hazard.
    Always steer clear of any cars at the wreckers that have the sticker "Air Bag Not Deployed" for that reason.
    It is suggested you invest your $100 reward being offered to a qualified tradesperson that can repair your SRS unit and then perform a systems check to qualify that the SRS is functional. It will be the best investment you may make.
    304runner's Avatar
    304runner is offline ( .Y. )
    VR 5.0 Ute & a 4runner with a VS SS trasplant
    Mar 2011
    Central Coast NSW
    Unless the people giving this bloke advice are qualified, id be very careful on guiding him through it. Mate, you have been in an acco so just imagine what could happen if you don't instal it correctly and you have another prang and the thing doesn't go off....
    I'm all for helping people out and saving a dollar or two but seriously don't take the risk... It would be like guiding someone through a full rewire of their house's electrical system, somethings bound to go wrong...
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by WizardofAUS View Post
    If you don't know what a viv is that's good it shouldn't need one..
    If you only have a single airbag in the drivers steering wheel this is good. All you need is to match the model colour and replace the whole steering wheel. when it comes the the sensors go new. give holden a call and tell them you wont a airbag sensor. if you only have the single airbag ask for the single sensor. also ask for thpretensionsersrs. Clock spring. Actually as i start to look over the price - that holden prices seems pretty good.
    Airbags is new $400+. pretensioners are $133 each. clock spring $120 The modual airbag sensor was $325 ( 4 airbags). their price is pretty good. Have you tried any auto electricians ?. My quote for replacement of 4 airbags and everything was $6,500!.
    scvs6's Avatar
    scvs6 is offline Donating Member
    1995 Holden VS Berlina 3.8L Supercharged V6 L67
    May 2011
    Ballarat, VIC
    I don't understand how the airbag went off. He didn't have a head on crash, he hit near the back left wheel......Doesn't the airbag only go off if you get hit fairly hard in the front?
    Quote Originally Posted by Jasper44
    For all you kids out there, when your about to have sex, just remember that it would be better if you went out and shot a police officer with a bazooka instead.
    Including car parts (VS, VT, VX, VY, WH etc), my WH Statesman, and other things listed on eBay.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by superchargedvs6 View Post
    you are correct, hence my first post.. if you really wanna check it before spending up big on everything. after your rear has been fixed up, take it to holden and ask them to check the SRS system, they'll tell you if the system is fine. i really doubt any smash repairs even think about the airbag system when the rear is damaged and nothing frontward the doors are touched.
    that would render most pre 2004 cars a writeoff in their books.
  15. #15
    VX Executive
    Jul 2011
    Thanks everyone for your help, its getting sorted out now.
  1. Step By Step Guide for Replacing the Crank Angle Sensor (CAS) on an RB30
    By detox_nath83 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-03-2009, 08:57 PM
  2. Replacing O2 Sensors on VT
    By EXCESSV in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-08-2006, 04:10 PM
  3. where are the airbag sensors located
    By Pedro13 in forum Electrical Wiring / Questions
    Last Post: 19-06-2006, 09:47 PM
  4. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
