Results 1 to 3 of 3
Thread: Major service need some advice on parts and what to get checked etc.
    vx s series 2
    Feb 2011
    vic
    Default Major service need some advice on parts and what to get checked etc.
    My car hasn't been serviced for 15,000 k's and it just hit 120,000 so its well overdue for a service. Since I only bought it at 118,500 I'd like to get mostly everything up to scratch so at least I know where its at when it get serviced again.
    What sort of spark plugs, leads (If i need them), oil and filters should I look at getting. I was thinking of mostly getting genuine holden stuff and then a k&n air filter or something? My brakes are squeeky as #### at the moment to so i'm gunna get the mechanic to have a look at them.
    Thanks and just let me know if there's anything else I need to look into
    Vsfan95's Avatar
    Vsfan95 is offline Vsfan95
    VT Series 2 Acclaim
    Dec 2009
    The parts you would require for a service would be transmission oil and filter service kit, oil filter and oil, spark plugs, ignition leads. also check your coil packs, coolant, brakes pads and rotors would need to be changed if they are squealing, fuel filter would need to be changed as well and check your heater tap, hoses and clamps, brake flush is also required. Your looking at about $500 for a complete overhaul
    If its Found On a Rubbish Dump its a FORD if it is Holden On its a Holden. Pick your poison.
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Like said above.
    I use Castrol Magnatec 10w40, which will be fine with that amount of k's.
    NGK plugs (don't buy Bosch!) I think from memory they are: BPR6EFS15.
    Oil and fuel filter: Repco, Valvoline or Ryco.
    Leads: Top gun aren't bad.
    Transmission is easy to self service if you have a bit of mechanical knowledge.
    Change power steering fluid too.
    The list could go on but that should get you started!
  1. MAJOR Service
    By BatGirl1101 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-12-2009, 12:44 PM
  2. major service
    By Marklar in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-04-2008, 10:49 PM
  3. major service
    By Holden V8 SS Ute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2007, 09:41 AM
  4. vx-s major service
    By Mark VX-S in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2006, 07:41 PM
