Results 1 to 12 of 12
Thread: vx ss noisey engine after cam
    VX SS II 5.7 6spd
    Apr 2010
    Default vx ss noisey engine after cam
    Recently had a cam installed, car feels and drives fine and goes hard sounds mean.........but when at about 2500rpm onwards it sounds noisey? like it has no oil, lifter noise? would it be the new hd valve springs, are they meant to be noisey,
    or am i just being paranoid..
    Oil levels are spot on, and changed every 5000k 10w 40 full synth. Any thoughts guys, any info would be greatly appreciated.
    kosta.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Changing the cam and fitting HD springs will increase valve train noise, as well as timing chain noise as there is now more load on the chain.
    Visit my Facebook page
    VX SS II 5.7 6spd
    Apr 2010
    VX Clubsport M6, Subaru Brumby-daily, TM Magna
    Sep 2008
    Auburn
    VX SS II 5.7 6spd
    Apr 2010
    Quote Originally Posted by johnno010684 View Post
    have you got an oil pressure gauge?
    na man was thinking of installing one, any thoughts....? ive heard that its not uncommon for ls1 engines to drop low on oil pressure and do bearings...
    keep it real, and keep it clean.
    vt/vx ls1
    Jul 2009
    Yo man, used comp cams, lifters,rods, r/r, beehive springs ect, higher then norm lift/agression cam n ls2 t/chain and yes i got much higher then your normal valve train noise,(at first i did think it could have been low oil pressure because the way it sounded like your also suggesting but i had checked and absoloutly everything was fine), every specialist i took it to had said it was all good to expect there to be more noise then normal staock valvetrain noise,
    In saying this before i build a couple of ls1's i really never had rebuilt a car motor before or beefed up the valvetrain so i was not use to the change in noise with different setups.
    BUT i would suggest getting some experienced people to have a listen to it, and yes get your oil pressure checked ESpecially at those revs the niose comes in at.
    Sep 2008
    Auburn
    Quote Originally Posted by koztek55 View Post
    i have recently changed my cam, springs etc and yes its a bit noisier but not that bad. did you install a double row timing chain? i would suggest buying and electrical oil pressure gauge to give you piece of mind as the oil light on the ls1 only comes on at around 8psi?? did you do the lifters?
    CV8 Monaro & VE SV6
    Sep 2009
    Did you fit a double row chain? To fit them (double row chains) you need to bend/ move the pick up slightly which results in a loss in oil presure. When the pick up is moved it breaks the tight seal. You might want to re think the chain. Either way get the oil pressure checked.
    VX SS II 5.7 6spd
    Apr 2010
    hey guys yeah there was a double row timing chain installed, all the work was done a performance specialist, i didnt do the lifters as i fell abit short on cash, but its hard to explain it not over the top noise, just noisier than what it was, i think i should probably save to change the lifters, anyone know roughly how much supplied and fitted?
    anyway im going to the place tommorow to get a slight adjustment done to the tune, il ask if they can have a look just to give me peace of mind.
    CV8 Monaro & VE SV6
    Sep 2009
    OK well ask them to put a gauge on the oil pressure. Better safe than sorry.
    To change the lifters you need to take the heads off, so I would expect that it would cost you around $500-$800 depending on who did it and by the time you got gaskets, etc.
    That said, most experts say there’s no need to change them. Are there are signs of wear on the cam you just took out? If not, I wouldn't bother changing them. But that’s just my opinion.
    VX Senator 300
    Oct 2005
    The 'gul, Vic.
    May also be a pushrod length issue.
    Senator 300 - the CLASSY C4B!
    LS1 - ETP215 @ 62cc, Comp 215/223 .602/.609 @111+3, 8.050" P/R, Morel link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster timing chain, OTRCAI, T-56 - RipShift, 3.91:1 rear, DiFilippo 1.75" 4-1s St/St HPC coated, DiFilippo twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune. 308RWKW. My ride:-http://www.cardomain.com/ride/389253...lden-commodore
    Sep 2008
    Auburn
    Quote Originally Posted by Aussiecv8 View Post
    i was thinking they might have put the spacers in wrong way which will choke the oil pressure, but i think you are just not used to the loudness of these motors after the valve train has been changed. definately get an oil pressure gauge mate
  1. noisey vr ute
    By jimmer79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-03-2011, 10:18 AM
  2. Noisey V6
    By Loupy31 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-03-2008, 09:45 PM
  3. noisey fan
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-06-2006, 11:35 PM
  4. Noisey Fan
    By vt busso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2005, 10:09 PM
  5. noisey v8
    By vrclubbie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2004, 09:54 AM
