Results 1 to 15 of 15
Like Tree4Likes
  • 4 Post By JustDylan
Thread: Welded diff??
    VU Ute 3.8 S
    Mar 2011
    Default Welded diff??
    Is a welded diff the only way besides an LSD or mini spool spinning both wheels?
    GEN3RATD's Avatar
    GEN3RATD is offline living the low life
    VXII SS
    Nov 2010
    Crib Point, VIC
    VU Ute 3.8 S
    Mar 2011
    Ok well I have both my wheels spinning but don't have an LSD. Any way to check for spooled or welded diff besides taking a look inside?
    GEN3RATD's Avatar
    VXII SS
    Nov 2010
    Crib Point, VIC
    sure you dont have LSD? i though S paks had them. look on the diff casing
    If it isnt tuckin, it must be suckin
    VU Ute 3.8 S
    Mar 2011
    Will do Tommorow but when I had the rear end jacked up the other week I spun the wheels and they both spin in opposite directions.
    JustDylan is offline Banned
    VN Berlina
    May 2010
    Mate the best way to tell is to do a tiny stand-still burnout and get a mate to watch, if it spins one wheel it's almost certainly a Holden LSD
    VZ SS
    Aug 2009
    Maitland NSW
    VU Ute 3.8 S
    Mar 2011
    Yeah that's how I could tell I had both wheels spinning I had a mate do a quick look while I lit em up a little. I'll have to check the casing Tommorow
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Jamiejamie View Post
    When the rear of the car is jacked up,and one of the rear wheels is turned by hand,if the opposite wheel goes in a different direction to the wheel you are turning,then the diff is an open wheel or single spinner diff.If the wheels both spin together in the same direction,the diff is LSD or similar.
    vt/vx ls1
    Jul 2009
    Quote Originally Posted by Brett_jjj View Post
    I tend to agree with this, my vx diff has a tag on the filler bolt, it says "use high performance oil or something", but im certain its not a lsd diff. it came from a base model vx executive with a factory gen3.
    VX 3.8 S1
    May 2011
    There is another way i've been told of. Don't know how and i'm unsure if it actually works though..
    Try using thicker diff oil?
    VZ SS
    Aug 2009
    Maitland NSW
    Quote Originally Posted by matqld View Post
    I would say it's a got a lsd
    VU Ute 3.8 S
    Mar 2011
    Yeah well theirs nothing to suggest it on the casing. I've either got an LSD or my mate is seeing things.
    spud_22's Avatar
    spud_22 is offline Ruled by the P
    95 VS Berlina
    Nov 2010
    Im only seeing smoke blowing of both tyres.
    3.08 LSD, 1.9.1 High Ratio Rockers, MACE CAI, Spacers
  15. #15
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    You have an open diff - no lsd, spool or welds.
    http://woteva.tk/
    If it ain't broke... I can break it for you
  1. welded diffs
    By james90vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2011, 03:35 PM
  2. VP Welded Diff
    By Tuff-VP-Wagzz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2010, 06:04 PM
  3. welded diff broken
    By MX_Leigh in forum General
    Last Post: 01-04-2010, 04:20 PM
  4. Welded Diff
    By DAMO_5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-08-2006, 02:44 PM
