will vz front struts and springs fit a vt
Yeah pretty sure they're all the same VT-VZ.
struts will fit but the sway bar links are different, vt-vy are the same, vz has a different link pin mount, vt have bushes top and bottom on the link pin and vz have a ball top and bottom of the link pin.
Thanks guys,Tried it and they don't fit.As glenn said sway bar links are where it all goes wrong and even if you tried to use a vz sway bar i suspect you could run into even more dramas,so we just bought a set of munroes with king springs and they're fine. Have to do the back now.I have the shocks and springs so I guess they'll be done at the weekend.
